Swapping switch with tone control
Discussion in 'Tele-Technical' started by dobrojoe, Feb 18, 2017.
  1. dobrojoe
    dobrojoe Tele-Meister
    England
    I find that I have a few 'sweet spots' for my tone control, maybe four. I was considering replacing the normal tone control with a rotary switch for pick-up selection and using a five way switch with four pre-set treble-cut settings. I use position 3 (series) and 4 (neck) mostly. Anyone tried this?
  2. Ira7
    Ira7 Doctor of Teleocity
    Coral Springs, FL
    And if you use a different amp where this doesn't work for you?
    I wouldn't reinvent the wheel and try to turn a pot into a switch.
    But damn, I admire your ingenuity and thinking.
  3. dobrojoe
    England
    It is more difficult to hit the sweet spot with a pot than with a preset switch. Always the same amp. I use the tone control more than the pickup selector.
  4. lammie200
    lammie200 Friend of Leo's
    San Francisco
    Not an electrical expert, but I think that you would need to measure the resistance at each setting that you like, then wire a capacitor on each leg of the switch that matches your measurements.
  5. dobrojoe
    England
    No, not a capacitor, a resistor. The capacitor remains a 0.047uF.
  6. dobrojoe
    England
    Where the rotary switch is concerned, I can get a 4-way 3-pole or a 6-way 2-pole. I really want a 5-way 4-pole, but I don't think I can manage that without CMOS.
  7. lammie200
    San Francisco
    You are correct. I miswrote what I was thinking. Guitarelectronics.com sells some rotary switches. I used a 6 position switch on my Jazzmaster.
    dobrojoe likes this.
  8. dobrojoe
    England
    Alas, we don't have the wealth of resources here in the UK. Yes, there is a 6-way 4-pole on guitarelectronics.com. Might have to bite the bullet and import it. Thanks for the tip ;?)
  9. BryMelvin
    BryMelvin Friend of Leo's
    Arivaca AZ
    FWIW you are pretty much reinventing the wheel. Look up Gibson's Varitone.
  10. dobrojoe
    England
    I know all about the Varitone, tried it in a Stratocaster and promptly removed it. The Villex passive mid range booster is much more effective but not really an option on a Telecaster without drilling a third hole. Don't want to do that and I'm not sure that it would work so well on a Tele anyway.
