Swapping pick up magnets
Discussion in 'Just Pickups' started by Les Paul lover, Nov 18, 2019.
  1. trancedental
    trancedental Tele-Meister
    London
  2. DHart
    DHart Friend of Leo's
    Scottsdale, AZ USA
    A2s seem to roll off the top end more than I prefer, so like you, I enjoy A5s.
    But you're right, the pot values are significant!
    crazydave911 and telemnemonics like this.
  3. Barncaster
    Northern California
    Disassembling a potted, covered pickup is not an easy task. Too much heat from a soldering iron can destroy insulations and cause shorts, killing a good pup. Its best to use a something like a very hot 30w pencil and quickly melt and suck up the cover retaining solder. This will minimize the heat soak that a lower temp/ longer contacting iron would impart.
    To dewax, mount the pickup, cover up in your solder station and warm it with a hair dryer. It might take 20 minutes on high but it will get the pup hot enough for gravity to flow the wax out but not hot enough to cause internal damage.
    With the solders and wax removed, the cover should slide right off of the still warm pickup. With Gibson Firebirds and Mini Humbuckers, remember that the guts are all loose in there so when the cover is coming off, gently hold the coils in place to prevent any mechanical stresses from being imparted to the fragile coil leads.
    After you have replaced your magnet, being careful to retain polarity orientation, check the pup with a multimeter to make sure all of your manipulations didn’t kill it. Check it again with the cover on and check it again after resoldering the cover. Have no illusions that this will be a clean, quick and easy process. But you will have learned a very valuable luthier skill.
    Rob
  4. trancedental
    London
    I just dewaxed an old pair of Epiphone 57CH humbuckers that came from a Sheraton, using a hairdryer with a cardboard box / kitchen tissues to soak up plenty of the excess wax.
    There's Alnico 5 magnets supposedly fitted on these pups, so I'm going to try them out with Alnico 2 & 4 mags & fit some new Nickel Pole screw bolts, without their original Gold covers.
    If they don't sound better after all that,, I know won't be able to resist completely rewinding them but using their original bobbins, base plates & other parts. :twisted:
    Will my table saw even cut small enough pieces of maple wood for traditional humbucker spacers? :confused:
    Do Korean keeper bars / slug poles or even bobbins make a real difference to P.A.F. tone? :eek:
    crazydave911 likes this.
