*Super* switch for strats?
Discussion in 'Stratocaster Discussion Forum' started by Scantron08, Jan 24, 2012.
  1. Scantron08
    Scantron08 Tele-Afflicted
    Jackson, MS
    I ordered a strat switch and I think what is being sent to me is this:
    http://www.allparts.com/4-Pole-5-Way-Super-Switch-p/ep-0078-000.htm
    "4-pole?" "Double-wafer?" "Super switch?"
    Wth is this? Is it a standard switch? If not, can I use it at all for standard strat wiring?
    Here's the sister thread to this one: http://www.tdpri.com/forum/stratocaster-discussion-forum/309826-linear-taper-v-audio-taper-pots.html
    Why is all of this so complicated - why can't I just order strat pots and a strat switch? My head hurts.
  2. Phostenix
    Phostenix Tele-Afflicted
    Phoenix, AZ
    You can use the Super Switch, but it will wire a little differently than a standard 5-way. And you won't use all of the terminals.
    It's complicated because people want different things. Flexibility breeds complexity. :)
  3. Wally
    IF you wanted a 'straight' 5-way Strat swtich, then you might not be happy with this SuperSwitch. FWIW, I have used these switches....and I find them rather restrictive. I can do more with push/pulls and mini-switches...and a standard 5-wat selector. Ex: I have a strat with 16 sounds....everything from authentic vintage Strat sounds to a 'bigger' Gibson type of sound to a Gretsch sounds....to some sounds that one can't put a 'brand' name on. All sounds are humbucking.....yes, authentic STrat sounds that are humbucking! (;^)
    I A/B'd it against a 1959 Strat that was in for a refret/set-up job.
    FWIW, there is a way to wire that switch for 'normal' STrat sounds. IT is an expensive switch to use for that purpose, though.
  4. Scantron08
    Jackson, MS
    Great, that's what I was afraid of. It appears you need custom slot size, screw spacing, and cavity depth.
  5. tap4154
    tap4154 Doctor of Teleocity Ad Free Member
    Southern California
    I used the StewMac 4P5W version and made the middle position bridge/neck. Also wired the back tone pot to the bridge. If you don't mind losing the middle-pup-only option it's a great mod (I love bridge/neck tone). This switch fit fine in my MIJ '68 reissue (1988) with no routing or changes to the control plate.
    http://www.stewmac.com/shop/Electro...nd_knobs/Megaswitches/Megaswitch_E-Model.html
    On my other Strat I used a push/pull on the bridge tone pot to get the neck/middle option.
  6. Wally
    That switch should not require any mods to the pickguard. I have seen some control cavities that would not accept it without a bit of wood removal...but that is rare. IT is not a depth but rather the width of the cavity that is the issue.
  7. Jack FFR1846
    Jack FFR1846 Tele-Afflicted
    Hopkinton, MA
    You can use it as a normal SSS switch. The only thing you're not using it for, really, is grounding the center tap of the hum for position #2. You will have to do some jumping of terminals because the superswitch (at least the musicman version I just put in a HSS strat) doesn't bridge between 2 terminals. You do that with wire ties, knowing that the terminal that goes to the output pot also goes to the terminal across from it. A knowledge of drawing at least a switch schematic to know what's switching what and where you'll need to bridge are a big help.
    I will totally agree that the normal bridging type strat switch is way simpler for a typical SSS application.
    I did not find that I had any problem with cavity depth or pickguard holes/slots.
