super reverb single channel reverb no tremolo new build
Discussion in 'Amp Tech Center' started by gianluigi, Sep 20, 2019.
  1. gianluigi
    gianluigi TDPRI Member
    Italia
    I just finished a new build ,a single channel super reverb with no tremolo
    the amp sounds clean but too much bright just like having a super bright switch engaged
    I changed cabinet
    reverb tank
    reverb cables
    guitar
    guitar cable
    4 different sets of power tubes
    too many pre amp tubes
    all voltages are ok
    checked the electrolytics with a capacitor tester
    no noise is present
    sometimes changing a tube seems to tame the treble but issue appears next time I switch on the amp
    double checked all resistors value
    the sound is metallic and you can notice it better playing the bridge/ middle position on a strat
    two techs tried to see if something is goin' on on a scope.and both of them told there's nothing wrong
    please need help
    thank you in advance
  2. Mexitele Blues
    Mexitele Blues Tele-Afflicted
    Westminster, CO
    What happens when you turn the treble knob? Are the speakers broken in?
  3. gianluigi
    Italia
    even with the treble low the metallic highs are present .it's a kind of out of phase thin sound ,metallic ,unpleasant
  4. schmee
    Do you have a layout we can see? If single channel you need to change one resistor, but really, I dont think that is your issue. Are all your ground points on the top of the board grounded? Trace and retrace your wiring.
    It's the 1500 ohm shown in this layout near the D location, it was 820 ohm on the dual channel.
  5. Mexitele Blues
    Westminster, CO
    Is it possible you wired the treble pot as a variable resistor (like the Bass knob) instead of a potentiometer?
  6. gianluigi
    Italia
    IMG_20190920_172351.jpg IMG_20190920_172359.jpg IMG_20190920_172406.jpg IMG_20190920_172410.jpg IMG_20190920_172419.jpg IMG_20190920_172430.jpg
  7. FenderLover
    Minnesota
    Maybe check your coupling cap values carefully. You may have neutered the bass completely and all you have left are highs. Do you have bass response with the bass knob?
  8. gianluigi
    Italia
    I think I found it!!!
    could it be the pilot lamp holder that was completly loose ?
    it should be a bad ground issue
  9. Wally
    Tighten that pilot lamp nut. Did that fix the problem? I doubt it.
    Have you made a voltage chart? Did the tech who put a ‘scope on the circuit do any voltage checks? The voltages may well be correct, a chart should be done in all cases, imho.
    I feel your problem is in the tone stack...as Fender Lover points out. Perhaps you could lift the tone stack and see what the amp does with it out of the circuit?
  10. gianluigi
    Italia
    this is what happened after tightening
    it's not the first time to me,years ago I had an amp with intermittent issue thin and dirty ,thin and clean,loud ,and it was a loose pot
  11. Wally
    Tightening a pot to make good ground is a different thing than tightening the pilot lamp, ime. That said, it needs to be tightened; and if the amp comes to life with ONLY the tightening of that nut, then I will take that under advisement. Did you tighten it?
  12. gianluigi
    Italia
    This is what I did and thi is what happened...
    Inviato dal mio LLD-L31 utilizzando Tapatalk
  13. Wally
    My apologies. Your English is far superior to my Italian, but I don’t do taptalk. Did you tighten the pilot lamp nut? If so, did your amp
    Start to work properly?
  14. gianluigi
    Italia
    Sorry.. I dont understand perfectly what you re saying... I don't do taptalk...
    Yes I tightened the nut and the amp started working properly
    Wally likes this.
  15. Wally
    Thank you, Gina Carlo. The taptalk reference was to the “Inviato dal IMO LLD-L31 utilizzando tapatalk”.
    Good find on the problem.
  16. robrob
    United States
    For a single channel AB763 if you don't add a "normal channel load" resistor to simulate the load the other channel places on the vibrato channel you'll have a lot more preamp gain than a real AB763. See the Blackvibe schematic and layout for how I did it.
  17. gianluigi
    Italia
    thanks Rob ,your suggestion helped a lot but I found out that cleaning the tubes pins made the amp sound perfectly.
    what do you think about it?
