Super Chump: Unnecessarily Complex Single Ended Amp
Discussion in 'Shock Brother's DIY Amps' started by shortcircuit, Mar 30, 2020.
  1. shortcircuit
    shortcircuit Tele-Meister
    North Carolina
    What has 2 gain stages, 2 cathode followers, single ended output, and a bunch of switches? Super Chump!
    Mockup:
    There's something seriously wrong here. Something I'd never done. Any guesses?
    Schematic:
    BigDaddy23, Snfoilhat and jsnwhite619 like this.
  2. DADGAD
    DADGAD Friend of Leo's
    Earth
    You could simplify it a bit by connecting the filament supply center tap to the cathode of the output tube, for some positive bias.
  3. shortcircuit
    North Carolina
    There's going to be 160V and 180V on the cathodes of the 6C4 tubes. It's below the 200V Vhk limit, but I want to play it safe.
  4. FenderLover
    Minnesota
    Not complex enough. I'd add another pot in the EQ bypass loop to form a divider with the Gain pot in bypass. That way you can simulate anywhere between EQ loss to full bypass and have variable variable boost.
  5. shortcircuit
    North Carolina
    I drew it out a bunch of different ways, and I can't figure out a way to do it without a bunch of mixing resistors, which would defeat the idea of a plain raw switch.
  6. FenderLover
    Minnesota
    Yeah, it wouldn't be full bypass either but I never found the huge boost with a bypass switch too usable as a performance feature.
    Snfoilhat likes this.
  7. tubelectron
    tubelectron Tele-Afflicted
    France
    Why not ? Yes it's quite complex, but you may be surprised by the result and the versatility...:)
    -tbln
  8. Danb541
    Danb541 Tele-Holic
    Oregon
    What language are you guys speaking? I don't understand a damn thing. I'm thinking I don't belong here.
    DrPepper, theprofessor and Switchy like this.
  9. David Barnett
    What do the switched networks from the cathodes of the cathode followers to the split plate loads do?
  10. FenderLover
    Minnesota
    If you have Merlin's book, it's figure 6.19. Basically it's a bootstrap circuit, where the the follower unloads the previous gain stage and the gain realized is close to the actual mu of the split-load triode. In this case close to an amplification factor of 100.
  11. shortcircuit
    North Carolina
    Chassis drilled and painted. Waiting for the paint to harden before proceeding.
    Everything I'd ever done, I'd stolen from Merlin. However, since I have both of his books, I don't feel bad.:p
  12. BigDaddy23
    BigDaddy23 Tele-Holic
    Subscribed!! Love your builds :lol:
  13. David Barnett
    I don't have the book, but apparently I need it...
    Looks like a form of positive feedback?
  14. elpico
    elpico Tele-Holic
    Vancouver BC
    I wouldn't either, anything you can say about tubes was already written by the 1960s. Heck, 99% of it was already written by Langford Smith in the 50s in RDH4. The rest of us are just rewriting what those great engineers figured out back when this stuff was worth spending engineers on :D
    DrPepper likes this.
  15. FenderLover
    Minnesota
    Not really, bootstrapping effectively increases the load impedance, creating less 'drag' on the output and allowing higher output amplitude.
  16. shortcircuit
    North Carolina
    Heaters and power supply done.
    Again, there's something that is a bit off.
  17. Mexitele Blues
    Mexitele Blues Tele-Holic
    Westminster, CO
    Will your volume pot be forming a variable high pass filter with the preceding coupling cap?
    shortcircuit likes this.
  18. shortcircuit
    North Carolina
    Ah fart! I thought I'd be ok with the 0.1uF coupling cap as I'd still have the full guitar frequency range down to 20k. What I overlooked was that 20k is half way on a 250k audio pot. Gotta put the output on the wiper and add a 2.2M resistor between the input and the wiper.
    I can drop the coupling cap to 0.047uF.
  19. shortcircuit
    North Carolina
    Criminy, what was I thinking? I would only need the 2.2M resistor if it was fixed bias.
  20. tubegeek
    tubegeek Tele-Afflicted
    Brooklyn, NY
    While this is definitely true, Merlin has a knack for explaining things clearly and thoroughly, and for answering questions by running tests. It's from a useful guitar amp perspective that is a valuable service to numbskulls like us. His examination of the grid current compression in a Fender Bassman cathode follower is absolutely riveting* and I'm actually not sure whether the explanation of how to analyze a cathode follower <IS> in RDH4? I'll have to take another look. If it is, I must've fallen asleep when I was reading that part.
    *for numbskulls like us.
