Super Champ XD - is this normal?
Discussion in 'Amp Central Station' started by 6stringelectric, May 2, 2011.
  1. 6stringelectric
    6stringelectric Tele-Meister
    Illinois
    I'll start out by admitting that I have never before owned a modeling amp so this may be perfectly normal.
    Anyway, I recently got a used Super Champ XD amp, with the footswitch included.
    The amp sounds great, and I like it a lot - but it has a very strange glitch.
    When I first turn it on no sound will come out at all, or sometimes just some strange radio-static-hiss sort of noise.
    Then I hit the footswitch to change the channel, and everything is fine.
    After doing this I can play through the amp as long as I like and never have another problem.
    Oh, I also do have both the guitar and footswitch plugged in before turning the amp on.
    So the question is, is this just a normal thing with modeling amps (or the SuperChamp) or should I suspect something is about to go horribly wrong?
  2. garymaddox
    garymaddox Tele-Afflicted
    Foat Wuth, Texus
    What happens if you don't use the footswitch? You might have a bad foot switch or something. Mine has never done this but I usually don't bother with the footswitch.
  3. 6stringelectric
    Illinois
    Good idea, I should have thought of that.
    Ya, with the footswitch unplugged it doesn't happen.
    And very odd, but it also doesn't happen if I turn the amp on first and plug in the footswitch after.
    Well, anyway, at worst it's a bad footswitch so no big deal. Thanks!
  4. ASC67
    ASC67 Friend of Leo's
    Minneapolis, MN.
    Are you letting the tubes warm up or expecting instant sound when turned on ?
  5. 6stringelectric
    Illinois
    I do let it warm up - I've used tube amps for years.
    But if the footswitch is plugged in, no sound comes out even after 5 minutes or more.
  6. robt57
    robt57 Telefied Ad Free Member
    Portland, OR
    Could also be the jack for the foot switch in the amp...
