Super Champ XD intermittent volume drops
Discussion in 'Amp Tech Center' started by elenore191, Nov 5, 2019.
  1. elenore191
    elenore191 NEW MEMBER!
    minnesota
    Hey Guys. Plugged in my Super Champ XD for the first time in a long time and notice intermittent gain and volume drops. Pretty severe at times, not consistent in amount or frequency of the drops.
    Thinking a tube going bad? Any ideas? Thanks!
    UPDATE:
    Turns out the problem is worse and happening most of the time now.
    I found out that the clean channel (channel 1) is also not working at all.
    -Elliot
  2. 39martind18
    39martind18 Tele-Meister
    Spring TX
    Experienced a bit of the same with my SCDX a week or so ago. There was a little bit of volume drop, tone changed a bit, then things would return to normal, only to recycle again in less than a minute. Turns out, my problem was with a connector cable between my guitar and the Roland GK3 pickup going bad. Replaced the connector cable, problem solved. Hope yours is as simple a fix.
  3. elenore191
    minnesota
    Thanks for the reply!
    I tried different cables and different instruments. Turns out the problem is worse and happening most of the time now.
  4. LightningPhil
    LightningPhil TDPRI Member
    Nottingham, UK
    Try switching the tubes about, or just reseating them. If they’re warming up and moving a bit, and the contacts are tarnished, this may help.
    The input jack on my X2 cased a similar problem.
    Does the line out work?
