Good job on the 33k snubbers, you could go higher, I've gone all the way to 100k on an EL84 amp to alter the way it clips when hitting the grids positive.
Aaah.. I don't think I want to go higher, my long time band partner has both a mesa boogie Studio 22 as well as the Caliber 50. These have 220k infront of the control grids. I've worked on them both, and have read Randall Smiths patent US4713624 which explains how it works, but I don't want to get to far away from that Fender thing. Also, when they realy hit their limits, the 6V6 can't sing in the same way as a EL84 with there aggresive mids and tight lows, and so can't take advantage of this compression effect. mesa uses an added supportive effect brought about by the high dropping resistor before the screens in conjunction with a larger elko.
6V6's sound at there best with thier warmer overdrive kept below thier farting wolf stage, and that is the balance I'm trying to achieve.
