Whatdidyoudonow
Hello fellow Tele fans. Some time lurker, first time poster, first time tele builder.
I know I'm not the first one who's made this mistake but I can't find much reference material to review.
I thought hey I'm not a genius luthier yet, I should probably try to build a body first maybe try to build a neck on a future build. So I bought this beautiful neck from Warmoth and thought it would be a good idea to have them drill the holes.
So neck fits. Not the tightest, but it's symmetrical with the body and after a series of 10 or so measurements over about a 1 week I get the same results when checking symmetry. I get within 2-5 100ths of an inch at 45.5 inches from nut to bridge. This morning it was dead on and I checked 4 times using calipers.
The neck screw holes are standard 1/8 inch with about a 9/16 depth. My plan for the last few weeks has been to cut either wood or metal 1/8 inch cylindrical stock to maybe 11/16, insert 4 of these into the holes, put into body and clamp down and create marks. I was then going use a drill press to drill out the 4 holes using these markers.
I'm starting to wonder if this will be accurate enough a method, especially now that I am dead on straight with the neck.
It seems to me I could better off long term
if I just fill the current neck holes with 1/8 inch stock and then use the template to "start over" and re drill both the neck and the body at the same time while clamped using the template I have. I am pretty sure I could keep the neck dead on this way.
So I'd appreciate comments pro and con. I'd prefer not to reinvent the wheel, but I'm totally amenable. I just want to build a good Telecaster.
Thanks in advance.......
