Suggestions about non-working Analogman Prince of Tone?
Discussion in 'The Stomp Box' started by RoscoeElegante, Sep 22, 2019.
  1. RoscoeElegante
    RoscoeElegante Friend of Leo's
    TooFarFromCanada
    Fine pedal, indeed.
    Suddenly stopped working some time ago now (been too busy to deal w/ it).
    One night it was working just fine. Next day, nada. Light won't come on, no sound, truly nada. Past warranty, of course.
    Never been treated harshly. I think I clicked it on with my fingers each time. Never been gigged, had anything spilled on it, been dropped, called a bad name.
    I emailed Analogman and they said mail it in and they "maybe" can fix it for a fee. But since I'm pretty broke and don't need it (I've learned that I prefer my break-up from the amp or via my since-acquired Joyo American Sound pedal), I'm thinking of just selling it as-is.
    Your advice?
    Get it fixed then sell it, or sell it as-is?
    If the former, what kind of $ might Analogman charge me to fix it, and then what % of that (plus the shipping) can I recoup by selling it?
    If the latter, what's a handsome, non-working Prince of Tone going for these days?
  2. MilwMark
    near Arnold's
    What a curious thread.
    Why not ask Analogman what they would charge and check Reverb and eBay for your other questions?
    artdecade and brbadg like this.
  3. jimilee
    jimilee Tele-Afflicted Silver Supporter
    Chattanooga
    Honestly, cost depends on what’s wrong with it. If it isn’t getting power, and the power source is good, I’d start looking at the 9v dc input.
    RoscoeElegante likes this.
  4. Ringo
    Ringo Poster Extraordinaire Silver Supporter
    Memphis TN
    Find someone who can work on pedals and have them look at it? Isn't it basically a Marshall Bluesbreaker OD? Shouldn't be too hard to diagnose for someone who builds / repairs pedals.
    Then again, checking completed sales for used POT pedals on eBay, recently they range from $132 -$209.
    So less for non working.
  5. RoscoeElegante
    TooFarFromCanada
    Analogman said charge would be "It depends." I haven't seen any non-working Prince of Tone on Reverb or eBay. Hence the (pretty sensible, I think) questions. Someone in TDPRI land might have dealt with a similar situation, right?
  6. RoscoeElegante
    TooFarFromCanada
    Thanks. But I'm kinda in the middle of nowhere, tech-wise. How does one go about finding a pedal fixer? The nearest guitar tech doesn't do that. We've got a massive tech-centered university right in town, but I'm reluctant to beacon in possible nut cases/junkies eager to snatch gear. (Big drug problem around here.)
  7. jimilee
    Chattanooga
    Maybe pedal building forums perhaps?
  8. tele_pathic
    tele_pathic Friend of Leo's
    St. George, UT
    If you can afford it, send it into Analogman and just get it fixed. Then if you sell it, you sell it. It's probably not going to cost a whole lot to get it fixed. And selling it broke...what, are you gonna get $50 for it, when you could get $150-200 for it?
    Bopcat, uriah1 and RoscoeElegante like this.
  9. RoscoeElegante
    TooFarFromCanada
    Thanks. Was dreading they might charge me a big chunk of what it's worth, making the whole effort worth the $50 just to be done with it, instead. Do you know what companies' ranges are for fixing pedals? E.g., a bench-time baseline+ that might make sending it to Analogman not worth it?
  10. tele_pathic
    St. George, UT
    Shoot, I'll buy it for $50 right now. Not kidding. Paid via paypal for merchandise to protect myself.
    To answer your question, I would think that AM wouldn't charge more than $50 to repair. Of course, you'll have to ship it there and figure out shpping back.
    RoscoeElegante and uriah1 like this.
  11. 11 Gauge
    11 Gauge Doctor of Teleocity
    Near BWI Int'l
    Have you tried a battery vs. external power, or vice-versa?
    It sounds to me like the most likely culprits would be either the power jack or the input jack, which establishes ground through the circuit, when a jack is inserted into the input.
    It's actually a good thing that the status LED does not come on, as this probably rules out a malfunction somewhere within the PCB itself.
    I'd start by double-checking if it will power up with either a fresh, new battery, or maybe even a different external power source.
    You might be able to visually see if there's an issue with the input jack:
    ...It would be an issue with the two upper "metal fingers" for the jack on the left-hand side. They basically will "switch closed" to allow a ground connection through them.
    MDent77, RoscoeElegante and uriah1 like this.
  12. uriah1
    Around
    Ya, mine will power off if connector wiggles or pops out.
    Like it, but, I think it is made overseas whereas
    the KOT is made local.
  13. Jupiter
    Osaka, Japan
    I know almost nothing about electrical stuff, but I have a soldering iron and I’d sure open it up and wiggle some wires around before I spent any money...
  14. Norris Vulcan
    Norris Vulcan Tele-Afflicted
    Somerset, UK
    To be honest that should be easy to fix - no surface-mount components, nice clear labelled pcb, simple circuit.
    I know that's not helpful if you're not that way inclined, but an electronics student/hobbyist should be able to sort it out. The schematic diagram would help, and it's out on the web.
    @jimilee has a good suggestion for checking the pedal forums. Quite often a search on DIYStompbox or TagboardFX will bring up similar problems/fixes.
    Otherwise you're paying Analogman for his time, maybe an hour or two at whatever his rate is. DIY is the answer !
  15. Torren61
    Torren61 Friend of Leo's Silver Supporter
    CA
    First thing I’d do is open it up and have a look and a smell. Does anything look or smell burnt? Then I’d change or install a 9v battery. The light not coming on suggests no power. Why isn’t it getting power? Did something come unsoldered? Unplugged? You could have had it open and probably fixed in the time it took to start this thread.
  16. RoscoeElegante
    TooFarFromCanada
    Hi, tele_pathic. Lemme (very gently) try the fixes other posters have recommended first. If it still isn't working, I'll PM you.
  17. RoscoeElegante
    TooFarFromCanada
    I did try a 9v, and it doesn't smell with the back/bottom still on. Will check further, though....
  18. allesz
    allesz Tele-Holic
    Italy - Bologna
    I get in just to throw my 2 cent:
    a) You say no light and no sound but does the signal get through the pedal when in bypass? If it doesn't it can be a faulty stomp switch.
    b) If the switch is good, the probably (since you have no sound and no led) you really should try cheking the circuit, from the power plug, with a multimeter, if you're lucky you will find a place where voltage stops.
