Success with adding filament virtual center tap to reduce hum..
Discussion in 'Amp Tech Center' started by JackL, May 23, 2020.
  1. JackL
    JackL Tele-Meister Silver Supporter
    Monroeville, PA
    Worked on my Lafayette PA622 conversion to guitar Amp today again.
    Installed the Filament Virtual Center Tap(2 - 100 ohm resistors to ground of the heater wires).
    It totally eliminated the hum I was getting when Amp was powered on.
    I still have more work to do but it's progressing to be more of a playable guitar amp.
    18watts and it has a good volume.
    The tone control doesn't have a very good range yet. I did reverse the Cap to the other side of the
    pot and that corrected the bass to treble when turning the tone control clockwise.
    I drew a schematic of where I'm at with the conversion.
    Jack
    Jlwctn likes this.
  2. robrob
    United States
    Did the amp have no 6.3v center tap and no artificial center tap?
  3. JackL
    Monroeville, PA
    No Center tap for the 6.3 v lines. They had it grounded on the 12ax7 on pin4. I took out the ground and added the 100 ohm resistors. What a difference, super quiet!
  4. JackL
    Monroeville, PA
    New drawing of changes I want to implement into the Amp. I'm going to try changing the Tone stack. What do you think of the new drawing?
    Jack
    robrob likes this.
