stuff rattling around inside my amp head
Discussion in 'Amp Central Station' started by doghouseman, Jul 13, 2020.
  1. doghouseman
    doghouseman Tele-Meister
    in your head man....
    there appears to be stuff rattling around inside my Bogner Atma. THe amp seems to work fine, but I am a little concerned about what the stuff might be.
    I tried to take it apart, but I started rounding one of the screws that held the front panel on, so I gave up.
    Any ideas on how to take apart and what the noises/items could be?
  2. corliss1
    Lansing, MI
  3. Peegoo
    Peegoo Poster Extraordinaire
    Yonder
    Could be anything...but if it's a stray blob of solder or anything else metallic such as adrift hardware--that could cause a short and spell death for the amp.
    Pop it open and have a look.
  4. corliss1
    Lansing, MI
    One of my favorite finds was in a sealed, closed back speaker cabinet. I found 6 pencils in there, and when I mentioned this to the owner he said his kids figured out they could put a pencil through the speaker jack hole and it would disappear inside. So you never know!
    Tim S and tubegeek like this.
  5. Bob Womack
    Bob Womack Tele-Afflicted
    Between Clever and Stupid
    You lock the door
    And throw away the key
    There's someone in my head but it's not me
    Bob
    ce24 likes this.
  6. jondanger
    jondanger Poster Extraordinaire Silver Supporter
    Charm City, MD
    May I humbly suggest that if you’re having a hard time getting it open, then you should probably take it to a tech to have them remove whatever is in there? As Peegoo said, if it is conductive, there’s a chance that it will cause a short that has the potential to do anything in the range of making the amp sound worse to total failure.
    One thing that does happen from time to time is that the screws that hold the circuit board to the chassis work loose. Looking at the Atma, I assume the chassis is oriented with the circuit board screwed to the top side of the chassis. If one of the screws worked its way out, it would be sliding back and forth on the shielding on the bottom of the head cab. What you don’t want is for that screw to get stuck between some tube pins when you move the amp. That’s how you smoke the thing.
    Here’s the counterintuitive thing. If it *stops* making that sound, then you definitely don’t want to turn the amp on. That would mean that whatever had been rattling around in there has got itself stuck somewhere, possibly in a place that could cause the amp to fail.
    hepular likes this.
  7. 3-Chord-Genius
    Winchester, VA
    I once read that later U.S. made Peavey amps had all kinds of things like dry dog food put into them during assembly as a form of protest by the workers who were about to lose their jobs due to the move to China.
  8. Les Paul lover
    Les Paul lover Tele-Holic
    England
    My Genz Benz Black Pearl 30's choke had gotten loose.
    When I opened it up, I realised a previous owner had attempted to fix that with gaffer tape.....
    I'm lucky I opened it straight away and fixed it. The choke frame is slightly bent from rattling around, but it didn't break or come off.
    tubegeek likes this.
  9. BigDaddyLH
    BigDaddyLH Tele Axpert Ad Free Member
    Kelowna, BC, Canuckistan
    Get yer amp head out of the gutter!
    Think with your big amp head, not the little one!
