Stubborn fret ends during installation
Discussion in 'Tele Home Depot' started by bunjamin, Nov 23, 2021.
Tags:
  1. Greenmachine
    Greenmachine Tele-Afflicted
    New Jersey
    Glad you found a solution. I made homemade cauls and used my drill press. Fret write is raidiused to a tighter radius than my fretboard. I tap in either end of the fret then I press. No problems thus far after three builds and one refret.
  2. Boreas
    Boreas Poster Extraordinaire
    Adirondack Coast, NY
    I am lucky enough to have an older (stronger) drill press that I use for my press. Works pretty well, but wouldn't want to go into serious production with it!
  3. Jim_in_PA
    Jim_in_PA Friend of Leo's Silver Supporter
    SE PA - Doylestown PA
    THanks for the ear worm...I can't get David Byrne out of my head now. :D
    Boreas likes this.
  4. Fenderbaum
    Fenderbaum Tele-Meister
    Bergen, Norway
    Hammering demands technique. Hammer is cheap, but a fret press gives you better results.
    I agree that frets should be a little over-bent if you hammer them. Not very much so with SS frets because they are very stiff. Always hammer the ends down first. Then the middle last.
    You can look around for a mini arbor press. Might save a $100. You need the Caul and inserts on the side.
    But I would go for the Stew Mac fret press for $300. Not crazy expensive.
  5. bunjamin
    bunjamin TDPRI Member
    Washington, DC
    Thanks everyone. The edges are indeed slightly rolled since this has been my main electric for almost 20 years. Looking closely, there also appears to be a seating problem off-edge, where the fingerboard's radius is accurate. I'm still leaning towards using a caul, since it solves two problems: I suck at hammering + wide fret ends. That allows me to go one at a time and use my CA glue where necessary.
    I imagine getting the fret ends flush with the rolled edge is more a matter of beveling & end dressing, rather than seating.
    Boreas likes this.
  6. charlie chitlin
    Egremont, MA
    This!
  7. charlie chitlin
    Egremont, MA
    If your fretboard is worn/rolled enough you might need to sand/radius the fretboard.
    If it falls off too sharply at the edges, frets might not be able to follow that.
    I'm sure you've noticed they're quite springy. It's not like you can pound them into shape.
  8. KokoTele
    KokoTele Doctor of Teleocity Vendor Member
    albany, ny [not chicago]
    Be careful not to do it with the over-radiusing. For a 12" radius fingerboard, I find that radiusing to 10" is plenty, but I get the best results with a very slight over-radius and pressing.
    If possible, I true the fretboard before installing so that the radius is consistent from edge to edge and the neck is flat.
    Sometimes the ends still don't like to stay down, and then a fret tang crimper is super helpful. StewMac sells a fancy one. Frank Ford has a page that shows how he used to make them before they could be bought.
  9. tigger
    tigger Tele-Meister
    Confoederatio Helvetica
    There is also the option of sliding the fret into place like it was done on old Fenders. Note that I haven't actually ever tried this, but I'm planning to. Make a radiused wooden tool the fret sits and slide it into the slot from the side. That could in theory stop the ends from wanting to get out as there is still wood above the barbs.
    Boreas likes this.
  10. charlie chitlin
    Egremont, MA
    I've never worked on one of these, but my suspicion is, they used a different kind of fret for this.
    You might not want to force a barbed tang in from the side.
    It seems to me it would tear up the slot.
    tigger likes this.
  11. Boreas
    I believe somehow Fender PULLED the frets through and didn't push them. I read how they did it once, but have forgotten the process. I could be FOS. May want to investigate their process first. It worked for them for many years.
  12. guitarbuilder
    old wrench and Boreas like this.
  13. Boreas
  14. stormin1155
    stormin1155 Tele-Holic
    Iowa
    Here's my fret press.... $60 arbor press from Harbor Freight, $75 fret press caul set from Stew-Mac, and some minor fabrication. Works great! If you have a drill press you can use those cauls in it too...
    KokoTele likes this.
  15. KokoTele
    How do you support the neck while you're pressing? I've had various ideas about how to make a support caul, but haven't gotten around to doing it yet. The typical one like StewMac sells doesn't support the transition or the heel, so you can do up to about the 15th fret before you have to reconfigure.
    Boreas likes this.
  16. stormin1155
    Iowa
    Don't need anything at the heel. It is flat and supports itself.
  17. Jim_in_PA
    Agree...and for the two or three transitional frets a stick of appropriate thickness under the curved portion of the neck with the heel clamped down directly to the worksurface takes care of things. 2 tapered shims inserted from opposite sides make for an exact fit for support in this case.
  18. guitarbuilder
    I sometimes stick random blocks of wood under the neck, as the caul pivots. I have used a cork lined caul like the stewmac one but that is only one radius and not tapered. When I cut a one piece Gibson style peghead, I save the waste wedges and sometimes put two together as a v block. The only necks that are problematic are the ones that are too thick to fit under the caul and arbor press.
  19. Teladjacent
    Teladjacent TDPRI Member
    Indiana
    I’m following this with great interest. I’m pepping to do a refret on my feet less conversion j bass and the fretboard radius is…. Let’s call it eccentrically compound.
  20. old wrench
    old wrench Friend of Leo's
    corner of walk and don't walk
