Stripped finish on Mahogany neck, do I need new grain filler?
Discussion in 'Finely Finished' started by Mhat, May 9, 2019.
  1. Mhat
    Mhat Tele-Meister
    Austin,TX
    I started a mahogany neck that I was going to do a transparent white nitro finish on the neck. I grain filled it with bellens grain filler, primed it and painted it. I then decided I liked it better with the natural mahogany so I removed the finish with Formby's Furniture Refinisher. It easily removed the finish, but would it have also remove the grain filler? Thanks!
    nojazzhere likes this.
  2. nojazzhere
    Foat Wuth, Texas
    Not sure.....but when I finished my mahogany neck from Warmoth, I simply finished it with MANY (twenty-five or thirty) coats of TruOil. I REALLY like the way it looks and feels.
  3. Mhat
    Mhat Tele-Meister
    Austin,TX
    Do you have a pic of your neck? I'm thinking about doing this too.
  4. nojazzhere
    Foat Wuth, Texas
    Not very good pics....sorry. Some places LOOK like there's a "texture" to the wood surface, but it truly feels smooth as glass. Hope this helps. When I did it, I would put on three or four coats of TruOil, letting dry completely between coats, then lightly steel-wool before next series of coats. Very time consuming, (especially when you're anxious to get the neck on the guitar) but I like how it turned out.
    El Tele Lobo likes this.
  5. El Tele Lobo
    El Tele Lobo Friend of Leo's Silver Supporter
    That looks fantastic, nojazzhere. I did a maple neck in 15 coats of Tru-Oil myself and it's one of the best feeling necks I've ever played. It was fun and easy to do. Granted, maple doesn't need grain filling, but Tru-Oil is a great finish nonetheless.
    20170716_183836.jpg 20170716_184545.jpg 20170716_183227.jpg 20170716_183813.jpg 20170716_183956.jpg 20170716_183217.jpg
  6. Mhat
    Mhat Tele-Meister
    Austin,TX
    Those both look great. I was concerned that the finish would be kind of dull, but these look great.
  7. Luthi3rz
    Luthi3rz Tele-Meister
    AZ
    Ah...look at the grain with a magnifying glass?
    Behlen Grain Filler is thinned with Mineral Sprites or Naphtha.
    Says that Formby's Furniture Refinisher Easily dissolves old varnish, lacquer, and shellac
    I doubt that what you had before used that stuff is still perfect.
    Why not play it safe and refill?
  8. Mhat
    Mhat Tele-Meister
    Austin,TX
    Yeah, I think I'll just fill it again to be safe.
  9. Freeman Keller
    Mhat, I use mahogany for almost all of my necks and finish every one of them in nitro. I usually use Zpoxy for pore fill but once in a while some of the paste fillers. If I had any doubt about the quality of my pore fill I would give it another coat (I usually do two coats sanded back level to the surface, then one more highly thinned coat). Here is a guitar that I just finished
  10. Silverface
    Lawndale CA
    It's very doubtful you would have removed Behlens grain filler. It is so tightly embedded you should just sand, apply a coat of lacquer sanding sealer (I prefer Mohawk) and then your clear coats (you can also use colored toners if you want to change the color a bit) - all thinly applied with 3 VERY light passes per coat except the final flood coat.
    Did you do a practice application of everything on scrap? you should - and now, especially because you're changing systems, you should get some scrap mahogany and apply the ENTIRE system (including final buffing) before doing any more work on the guitar.
    Learn the products and how they interact & refine your technique on practice material - not on the real thing!
