Peterquelle
Hi,
I have a DIY Les Paul Junior (not from myself) that I bought with a compensated wraparound. The problem with this guitar is, that the neck is not in the right angle for such a bridge. I never could get the action as low as I wanted, but the bridge was already flush on the body. So I switched the bridge for an Allparts Short Tele Style with compensated saddles (This is why I post this here). I got it set up now, action and intonation is spot on, but the D and B string run right over the height screws of the saddles. First I thought I installed the saddles someway wrong, so i switched the D/G and B/A saddles, but it looks excactly the same. The way the saddles are set, the height screws are already lower than flush, so its not a problem. But did mess something up when installing the bridge? The strings run right in the center of the fretboard. On the picture it looks like the bridge itself is slanted, but at least to the P90 cover its parallel.
Edit: And yes, I slipped badly on one screw..
