String's gauge bias
Discussion in 'Bad Dog Cafe' started by albatros, Feb 14, 2020 at 3:02 PM.
  1. albatros
    albatros TDPRI Member
    ITALY
    Hi everyone,
    did you ever measure your strings?
    These are brand new fresh sets.
    Far below the 0.36 expected.
    Is my finding of any interest for us guitarists?
    Thanks
    Bye
    Francesco [​IMG][​IMG]
    Inviato dal mio SNE-LX1 utilizzando Tapatalk
  2. don71
    don71 Tele-Afflicted
    Central Missouri
    On occasion I measure with calipers, not often. Never experienced them not matching. Perhaps a calibration error with the calipers?
    brookdalebill likes this.
  3. EsquireBoy
    EsquireBoy Tele-Holic
    Paris, France
    How accurate is your tool?
    It looks a lot like mine, with which I can get close enough but yet different values between two measurements.
  4. JL_LI
    JL_LI Friend of Leo's
    Long Island, NY
    Those look like wound strings to me. Look at the measuring blades of your caliper. There, a knife edge at the tip and a full thickness blade farther up. Measure your strings off the guitar using the thick part of the blade. 0.36 will measure 0.36. Then measure with the knife edge. It will fit a hundredth of an inch or so into the gaps between the wire wraps of the wind. That’s where the 0.34 measurement comes from. The trick with any tool is knowing how to use it. I’m more comfortable with a measuring microscope but my Mitutoyo digital caliper has never let me down for a quick and dirty go / no go measurement.
  5. guitartwonk
    guitartwonk Tele-Meister
    People's Republic of Blighty
    This.
    I have calipers exactly like these. Two things can go wrong here. One, what @JL_LI said. Two, have you zeroed the calipers before starting?
    JL_LI likes this.
  6. albatros
    ITALY
    I adopted your method but the result is identical [​IMG][​IMG]
  7. jimgchord
    jimgchord Tele-Afflicted
    victor,ny
    Looks like a cheap caliper.
    That Cal Webway likes this.
  8. MarkieMark
    MarkieMark Tele-Holic
    Eastern USA
    The term "nominal" comes to mind.
  9. dougstrum
    dougstrum Tele-Afflicted
    blu ridge mtn cabin
    If you want a truly accurate measurement a micrometer would be the better tool.
    ponce, SheldonP and Obsessed like this.
  10. Obsessed
    Montana
    Just because a tool has a digital readout, doesn't make it accurate. The fluctuation of a string is not going to vary that much. It really does take practice to get consistent "good" results from calipers. As mentioned by @dougstrum , micrometers would give you much more accurate results without as much practice. As @JL_LI mentions about measuring wound springs with the tip is going to give you varied results, and at the same time, if you use the wide flats of the calipers, that will give you "bad" average results. Don't forget to always wipe the measuring surfaces of all measuring devices before each measurement and always check the "0.00" reading before each and every measurement.
    That Cal Webway, dougstrum and JL_LI like this.
  11. JL_LI
    Long Island, NY
    A micrometer will give consistent results of the string if its jaw is closed with the same tension each time. Consistent results from a caliper requires the same care with consistency of tension. The down side to measuring with the wide flat of a caliper that it required a little more skill so that there is no curvature induced in the string where it is measured. As with any tool, choosing one appropriate for the job is critical to your success, as is skill that only comes from practice. Now let's think about our little community here. A good many of us are self taught. Technique is often no more refined than what's necessary to get the job done. There are a few of us degreed in STEM curricula, even fewer with an advanced degree. How many do you suppose know what a Vernier scale is or how to read it. A digital micrometer takes that challenge away, but how many with no other use for the thing than measuring strings will be willing to spend as much on a micrometer as a good Pacific rim guitar?
    What amazes me more than anything else is how we get into esoteric discussions about things that really don't matter. Does anyone really believe that Daddario, Ernie Ball, Dunlop, Fender, or any other prestigious company has such poor quality control that close enough is good enough?
    dougstrum, Nick Fanis and Obsessed like this.
  12. Obsessed
    Montana
    Yup. Point being that just because you can read a digital measuring device, does not infer that it is being used correctly. In addition to this is the use of feeler guages or other measuring devices for measuring string "action". As @JL_LI mentions about the tension of micrometer use, so is the case with how to properly use feeler gauges too.
  13. Nick Fanis
    Athens-GREECE
    You'd be surprised my friend, you'd be surprised... :lol:
    albatros likes this.
  14. 1300 E Valencia
    Fullerton CA
    They have medication for this.
    I mean, besides beer.
    Frodebro and dougstrum like this.
  15. TheGoodTexan
    TheGoodTexan Moderator Staff Member Ad Free Member
    Nashville, TN
    Measure the wound strings length-wise, rather than measuring a cross section of it. Maybe you’re measuring between the winds??
    It might be more uniform if you measure across the top of several winds.
    JL_LI likes this.
  16. albatros
    ITALY
    IMO string's quality controls in basic cheap sets are going down as far as premium expensive strings are put on the market. This is only my personal opinion.
  17. Frodebro
    Seattle
    This is something that, quite honestly, falls under the category of "close enough for rock and roll."
  18. Modman68
    Modman68 Tele-Holic
    La mesa
    Wait till you measure the values of your pots and capacitors...
  19. kbold
    Could always send your calipers off to a standards laboratory for calibration.
    Would cost a lot more than the calipers though.
  20. Clive Hugh
    Clive Hugh Tele-Afflicted
    Western Australia
    You are only talking about .001”, thats nothing, in manufacturing a tolerance of +/- .001” is common and completely within spec. Agree with the comments on calipers, I’m a machinist and when I learned there was no such thing as digital, we had vernier and micrometers, verniers and digital are for indication, for final measurement you use a mic.
