String Trees - Yes/No? Why?
Discussion in 'Telecaster Discussion Forum' started by Alienjohn, Jul 19, 2021.
  1. Alienjohn
    Alienjohn TDPRI Member
    Columbus Ohio
    Some Teles have none, some just on the E/B- Some have add'l tree on the D/G
    If the strings are not popping out of the nut are they necessary?
    Do they affect tone? Sustain? Play-ability?
    Are different brands/types of trees better or worse?
    Proper location of tree(s) on a Tele?
    Planning a build. Asking the people who know !
    Thanks
    JustABluesGuy and highwaycat like this.
  2. Killing Floor
    Killing Floor Poster Extraordinaire
    Austin, TX
    The string needs to "break" over the nut sufficiently to establish a witness point that you need for intonation. Because some strings, usually the plains, are further away from the nut the angle is lesser. The string tree can establish a higher angle over the nut. It's not a hard rule because a lot of other factors like headstock shape and height of the posts and the setback or tilt of a headstock would affect it. But in general, headstocks like those on Teles could use a little help on some strings. No hard rule why some have 1 or 2 or none. My baritone Tele has none and it intonates well but I have plucked the high E out of the nut slot, that wouldn't happen if there was a tree. I actually have a vintage Fender round tree but I am too lazy to install it.
  3. UPtele
    UPtele Tele-Meister Gold Supporter
    MI
    I dunno I have a few guitars with staggered tuners with no string trees, I got no problems
    Tyuk and Alienjohn like this.
  4. brookdalebill
    Austin, Tx
    I avoid them whenever possible.
    Two of my guitars are tree-less.
    My EJ Strat, and my now busiest guitar, a B bender Cabronita.
    Both of those guitars stay in tune beautifully, BTW.
  5. pi
    pi Tele-Meister
    bay area, CA
    All my guitars have them only on the B&E strings, except one that has staggered tuners, which has no tree.
    Why? 2 of them came the way they came, and the other 2 were partcasters and I did it that way because that's the way they should be.
    LPTyler likes this.
  6. UPtele
    MI
    It's an easy thing to change either way tho. If you have one and don't need it. Or need it and don't have it
  7. jrblue
    jrblue Friend of Leo's
    Santa Barbara
    good break angle --> good downward pressure on nut --> better sound and sustain. Most Teles and Strats do not have a good break angle on the first 2, even 3 strings (unless the tuners have staggered posts). Even if the strings don't pop out of the slot, they still have little downward pressure on the nut. The fact that Fender added the trees verifies the necessity, as that company never added parts (and costs) that were not strictly necessary.
    AAT65, Amby, Telekarster and 3 others like this.
  8. Chicago Matt
    Chicago Matt Friend of Leo's
    Woodstock
    This ^^^
    On my Fender vintage style necks with the tree further away from the nut, I'm really liking this aftermarket 3-banger. No ringing behind the nut on the G string, and nice uniform angle over the nut for all the unwound strings. $5 and no need to drill an additional hole. They also come with 3 spacers of varying heights. I'm using the lowest one. I've experienced no tuning problems even after a lot of big bends.
    Crobbins likes this.
  9. charlie chitlin
    Egremont, MA
    If you get the hang of leaving the right amount of string so you can wind it right to the bottom of the post, you can bypass the string tree.
    I think they stay in tune better like that.
    Chicago Matt and green_henry like this.
  10. Blue Bill
    I had a couple Teles that had a problem with the e string jumping off the nut, ending up where it's not supposed to be. It's very disconcerting, being on stage and having the e-string just disappear. Now, all my Fenders have trees. Problem solved.
    Chicago Matt likes this.
  11. Chicago Matt
    Woodstock
    I did the wind to the bottom of the post for a couple of years and still had trouble with the ringing behind the nut on the G string. Then one day I was watching Guthrie Trapp, whom I've been following for awhile. I thought there was something unusual about the string tree on his headstock and looked closer. That's what convinced me to try a triple tree. It's been a real problem solver for me.
  12. fender4life
    fender4life Friend of Leo's
    los angeles
    They change the break angle at the nut and may slightly affect string tension and more likely affect tone, even if just slightly for 2 reasons. 1-the break angle as i said will sound slightly brighter or more strident with trees. 2-they stop the string behind the nut from ringing out loud enough to cause a loss of clarity by adding a slight dissonance to the sound. This for me is an issue on the G string since all my strat/.teles have only a E/B tree. The wounds generally are not loud enough to cause that issue but the plains can and the G is the only plain w/o a tree. So i fold a small piece of scotch tape over the G behind the nut whenever i restring any fender. I can definately hear a less cluttered sound, and when it's REALLY bad i can hear the G string distinctly adding some dissonant tone thats really bothersome. Been thinking of ditching the tape and getting some of those three-string trees that also tree the G string.
    highwaycat likes this.
  13. UPtele
    MI
    If it's ringing behind the nut that's the issue stuff a pair from those pantry dropping licks in there
    richiek65 likes this.
  14. Stanford Guitar
    Stanford Guitar Friend of Leo's
    On guitars that don't have enough headstock break angle, you get the sitar effect without string trees on the treble strings.
    JustABluesGuy likes this.
  15. fenderchamp
    fenderchamp Friend of Leo's Ad Free Member
    omaha
    need to have 1 and only 1. It needs to be a disc. Only one reason for it. Leo put it there!!
    not really.
    Rig up your tele however it works for you. If you are popping strings out of the G/D slots you probably want another retainer or more neck angle or something.
    Telecaster setup is always a series of minor compromises adapted to an individual player on an individual instrument. If it's not, you probably own too many.
    How do I know this?
    shallbe and Chicago Matt like this.
  16. Blackmore Fan
    Blackmore Fan Tele-Afflicted
    Well, there's sometimes a difference between what is ideal and what is practical. I think that those of us who know much about Eric Johnson know that's he's a perfectionist. His signature Strats don't have string trees--his design increases the break-angle where his Strats don't require string trees. But its not a crime if a particular model needs one or more of those to make notes ring out. The outcome (the sound) is the important part.
  17. jaxjaxon
    jaxjaxon Tele-Meister
    SanluisObispo CA.
    They can serve several purpose's. Break angel off the nut, stopping harmonic sympathy notes, adding weight to the head stock to get more sustain.
    Blackmore Fan likes this.
  18. Tyuk
    Tyuk Tele-Meister
    BC
    My MIM strat always had tuning issues and I couldn’t figure it out until I bypassed the string tree. Never had any tuning issues since; no issues with sustain either. Same with my MIA tele; string tree bypassed and couldn’t be happier with it.
  19. lammie200
    lammie200 Friend of Leo's
    San Francisco
    Staggered tuners. No string trees.
    Tyuk and Blackmore Fan like this.
  20. highwaycat
    highwaycat Tele-Holic
    California
    Ya TWO Graphtec string trees set high with staggered tuners.
    You can make a better bone nut if you use the string trees..less material on top of the nut...
    Chicago Matt and Blackmore Fan like this.
