cousinpaul
@redhouse_ca
The nut looks bad as in sloppy work. Even so, it could be functioning properly.
I recently purchased an American Vintage '58 telecaster, which was barely played and pratically new, and found out that most strings seemed really stiff, especially the high E string, when bending, which I do a lot of. It seems that the strings are under tension and they hurt my fingers when I play, which isn't the case with my other vintage speced guitars such as my Strats. My luthier said that the neck angle seemed right and I went ahead and heightened the stock saddles to avoid any fret outs when bending on the high E and B.
My question is the following: how does one reduce the tension or stiffness especially in the high strings? Is this normal on a telecaster? Should I adjust the position of the saddles (forward or backward)? Could it be the action or possibly the neck angle?
Specs:
- 7.25" radius
- stock saddles
- 9-42 strings
- bone nut
- vintage fret
Any info would be appreciated.
Specs:
- 7.25" radius
- stock saddles
- 9-42 strings
- bone nut
- vintage fret
Specs:
- 7.25" radius
- stock saddles
- 9-42 strings
- bone nut
- vintage fret
I'm curious to hear what was done to the guitar, and how it plays after the tech has worked on it...I brought the telecaster in to my guitar tech today and he confirms that it is the original stock Fender nut based on the traces of the glue and by looking at it. It must have passed QA at Fender for some reason. Anyways, it will undergo a complete setup and the nut will be completly reworked. I will post some photos once I get it back in a week or so.
