fushifushi
Hi everyone,
I'm trying to set up my partscaster Tele (MJT body, Warmoth neck, 10-16" compound radius). The problem is that the low E buzzes too much when fretted (no buzz when strummed open). Even when I use a softer attack I still get buzz. The A also has a bit of buzz when fretted but it's an amount I can live with.
Initially there was not much neck relief, so I've gradually added relief and raised the saddles in an attempt to reduce the buzz. Now the neck relief and action are pretty high and still there's buzz. I'm not sure where to go from here. Here are the specs I'm measuring.
Any thoughts?
Thanks,
Jason
- Relief - 0.018" (measured by capo-ing the first fret, fretting the 21st fret, and using the biggest feeler gauge at the 8th fret that doesn't nudge the low E string)
- Action on low E - 8/64ths (measured at 17th fret)
- Action on high E - 5/64ths (measure at 17th fret)
Any thoughts?
Thanks,
Jason
