Strat Sound?
Discussion in 'Stratocaster Discussion Forum' started by Pineears, Jul 15, 2020.
  1. Pineears
    Pineears Tele-Afflicted
    I can’t remember, haven’t had a strat for 5 yrs. What does the bridge plus mid position relative to just bridge and just mid sound like. I just dropped a mid into my Tele and the bridge plus mid sounds weak and uninteresting. Mid alone sounds great, it’s a Cavalier Lioness (very straty).
    cravenmonket likes this.
  2. cravenmonket
    cravenmonket Tele-Holic
    Northern California
    A lot of people describe it as "quacky".
  3. fendrguitplayr
    fendrguitplayr Doctor of Teleocity Silver Supporter
    New England
    The quack sound.
    Doctorx33 and cravenmonket like this.
  4. drmordo
    drmordo Tele-Afflicted
    Miami, FL
    The whole song is drenched in position 4 on a Strat, but the solo starts ~ 3:00.
  5. johnnylaw
    johnnylaw Tele-Afflicted
    New England
    There will be some phase cancellation that yields the "squak". Think later Albert Lee, for instance.
    I would consider playing around with pickup heights to optimize abailable swith selections for your own playing style.
    I roll the volume knob on the guitar around a lot while playing, so that volume dip is "fixed" quickly. I never run the guitar volume wide open because the amp is always running more than I need.
    I never measured bridge (or middle) pickup distance from the saddles on a Strat or Tele, but that placement really effects tonality. They may be different enough to un-Strat your Strelecaster some.
    Telecaster88 and cravenmonket like this.
  6. cravenmonket
    Northern California
    A+
  7. GGardner
    GGardner Friend of Leo's
    NJ
    Position 4?
    stnmtthw, Lawdawg, Mike M and 2 others like this.
  8. cravenmonket
    Northern California
    Whenever I listen to this I get terrific GAS for a Strat.
    Then I throw on Brothers In Arms and I add a bit of Les Paul GAS to the experience.
    Double trouble.
    GGardner likes this.
  9. Daddy Hojo
    Daddy Hojo Friend of Leo's
    Kentucky
    It sounds weak and uninteresting...
  10. reckless meanie
    reckless meanie Tele-Holic
    Bend, OR
    Is it wired up right, it sounds like you might have them out of phase?
    AAT65, Ian T and richiek65 like this.
  11. fasteddie42
    fasteddie42 Tele-Afflicted
    Tip of the Mitt
    it sounds like a filter on some frequencies.
  12. Telecaster88
    Telecaster88 Tele-Afflicted
    Midwest USA
    I play a lot of arpeggios, single note lines, and position two has an almost brittle, wiry (but pleasant) brightness to it when playing single notes... A little thicker around the bottom but very bright at the top. Very chimey. I don't use it much for strumming ... But for the single note chime it's great.
  13. SixStringSlinger
    SixStringSlinger Friend of Leo's
    Space
    The intro to "Sweet Home Alabama" (and a lot of the rest of the recording) is pure Strat middle+bridge.
    awasson, stnmtthw, Doctorx33 and 2 others like this.
  14. Pineears
    It’s wired right I’ll get to height adjustments later today. Im waiting for a pickguard. 3 position switch, no neck pup. BADEF49F-8236-420B-9AF1-F53DDCA12962.jpeg
    That Cal Webway and drmordo like this.
  15. ScribbleSomething
    ScribbleSomething Tele-Holic
    San Antonio
    @Pineears you may not like the in between positions.
    Something that helped mine out the most was to switch from tradition wiring to Eric Johnson wiring. It’s the jimmy Vaughn wiring with bigger capacitors.
    Then I raised the middle pickup until the in between positions are about as loud as the neck and bridge. Works for me.
    awasson likes this.
  16. Pineears
    My mission was to get 3 positions I like. Before (standard 2 pup), I liked bridge and bridge plus neck. Now I like bridge or mid.
  17. telepraise
    telepraise Tele-Afflicted
    Tampa Bay
    Should be a major quack (on a strat at least). Check with Rob, you may have to reverse to the leads on one of the pickups to get them in phase. IIRC it's also Rob who pays attention to the polarity of the magnets and he can direct you on how to reverse the polarity using a magnet.
  18. Mrbob135
    Mrbob135 Tele-Afflicted Silver Supporter
    Franklin, VT
    This is the first song I think of when I think position 4:
  19. schmee
    It should sound like this:
    ndcaster and Lawdawg like this.
  20. chris m.
    Santa Barbara, California
    The quack positions are slightly weaker than the other 3 positions due to phase cancellation, but not dramatically weaker. If dramatically weaker you may have wired out of phase and should try flipping the wires on the middle pickup. This is easy to do if you mix something like Fender and Seymour Duncan pickups because they often have exactly opposite wire color codes.
    AAT65, summer_69, richiek65 and 2 others like this.
