Strat bridge/saddles mod
Discussion in 'Stratocaster Discussion Forum' started by fenderjaguar, Aug 5, 2021.
  1. fenderjaguar
    fenderjaguar TDPRI Member
    poland
    I've always hated how the end E saddles can rock/move/slide around and even buzz.
    I simply took the brass earth fork out of a UK plug and hack sawed it shorter. Then scored/sanded both the bridge plate and the bottom of the brass, then stuck 2 of them on with super glue.
    This feels really solid now. This is a squier jazzmaster mini, but it has strat hardtail bridge:
    https://ibb.co/5xzj40R
    https://ibb.co/xGL82X8
    https://ibb.co/FqvC7Zr
  2. LutherBurger
    LutherBurger Poster Extraordinaire
    NYC
    That is precisely why I will never own a bridge like that (top-loading, with six block saddles). The strings lift the saddles at the back and push them down at the front. If you kept adding neck relief, I bet you could eventually get the saddles to float above the plate.
  3. Lonn
    Lonn Friend of Leo's
    Indiana
    Not sure what you're talking about unless you haven't had the guitar setup right. I've never (out of about 800 Fender style guitars) had a loose E saddle once the guitar is setup.
  4. fenderjaguar
    poland
    no, the combined downforce on the saddle is the same as if the string had just gone directly from the ball end hole to the saddle. It can't lift the saddle up, that would be opposite of reality.
    I appreciate that the force on the saddle is probably different to string thru though (which is actually a pretty easy mod to do on this bridge).
  5. LutherBurger
    NYC
    I'll rephrase: the string applies pressure to both the top and bottom of the saddle, instead of just the top. It's a ridiculous design.
  6. fenderjaguar
    poland
    it doesn't have any more uplift on the saddle than the green line would in my previous uploaded picture.
  7. alex1fly
    alex1fly Tele-Meister
    Colorado
    Nice!! I love seeing hacks/mods like this... household objects used to improve the functionality of a musical instrument. Thanks for sharing!
    fenderjaguar likes this.
  8. LutherBurger
    NYC
    How did you measure or calculate the forces and angles, and generate the picture?
  9. fenderjaguar
    poland
    I think the amount of force you get from a pull in straight line is the same force you get from a pull that has been diverted, but then returned to the same place. I try to show in this picture I upload:
