Stompbox Output Jack Grounding
Discussion in 'Burnt Fingers DIY Effects' started by peterg, Apr 11, 2013.
  1. peterg
    peterg TDPRI Member
    Toronto
    Does an output jack's ground tab need to be connected to anything?
  2. LarsOS
    LarsOS Tele-Holic
    Norway
    Yes, it needs to be connected to (signal) ground.
  3. peterg
    peterg TDPRI Member
    Toronto
    Thought so. Some diagrams I've seen don't show it though.
  4. bblumentritt
    bblumentritt Tele-Afflicted Platinum Supporter
    Austin, Texas
    In the drawing above, signal ground is connected to the sleeve of the input jack, and hence, the box. The output jack ground tab is also grounded to the box. The box is acting as circuit ground, and both jack sleeves are in contact with the box.
  5. LarsOS
    LarsOS Tele-Holic
    Norway
    If the stompbox enclosure is made out of a conductive metal, that might be enough, if the enclosure is grounded, all depending on the design of the jack.
    But in your illustration, it seems like it's the inner (hot) lead that is missing? That's strange.
  6. limbe
    limbe Tele-Afflicted
    Stockholm,Sweden
    I think peterg calls the ground lug for "inner" because it´s closest to the box and the hot lug for "outer" if I am not mistaken.The groundlug on the output jack is grounded in the metallic box.
  7. peterg
    peterg TDPRI Member
    Toronto
    So if it's a metal box i.e. Hammond 1590B then a wire from the output ground lug to somewhere else is not needed?
    I can't take credit for the diagram. I picked it off a site. Just not sure which one.
    Limbe - we are reading the drawing the same.
  8. tjk3052
    tjk3052 Tele-Holic
    The wild wild midwest
    It's good practice to connect it by wire. That way it stays connected if the jack comes loose.
  9. LarsOS
    LarsOS Tele-Holic
    Norway
    Yes, if it's a metal box, you can use the box as ground. But as tjk3052 said, it's good practice to run a ground wire anyway.
    There are several reasons for that. Redundancy is one of them. Soldered connections having lower resistance is another (better toooone - may or may not be noticeable). A dedicated ground wire will also make the circuit easier to understand for the person who is to troubleshoot it 50 years in the future (one can always hope). And I'm sure there's a couple more reasons, but I can't think of any right now, and I've got work to do, so I shouldn't be reading TDPRI in the first place. :oops:
  10. peterg
    peterg TDPRI Member
    Toronto
    Thanks All
  11. limbe
    Stockholm,Sweden
    Using lock washers and tightening the nut will make it harder for the jack to come loose.
    I use them most of the time.
