stijnkenens 's 2012 Challenge Build Thread -- COMPLETED
Discussion in '2012 TDPRI Tele Build Challenge' started by stijnkenens, Mar 14, 2012.
  1. Barncaster
    Northern California
    Go Stijn!
    This is one of my favorite builds. I just can't wait to hear it. There will definitely be some very unusual resonances with this guitar. :cool:
    Barncaster
  2. stijnkenens
    stijnkenens Tele-Meister
    antwerpen, belgië
    Nop, I can't ...
    post some pics as soon as I can !
    s.
  3. stijnkenens
    antwerpen, belgië
    Ok, almost there ...
    But still a lot to do ...
    Drilled dots:
    drilled holes for tuners and burned the headstock:
    prepared the lefty bridge for multi-scale neck:
    first I've put the bridge on the right spot, then I used a loose bridge saddle to calculate the right position for treble and bass E string.
    use a pointy thing for the right location and drill:
    When drilled use the bridge as a guideline for the string through channels:
    Take the bridge of again, and locate the holes on the back:
    Picture with the string ferulles on the back is coming soon.
    Did I mention my little mistake???
    Look at the left sight of the bridge:
    Drilled out the hole for the jack:
    Neck weight is:
    And lacquer:
    s.
  4. Ike57
    Ike57 Tele-Meister
    Netherlands
    Fortunately it's not a mistake that will have any influence on the playability. I know if you had time you would be able to fix it, one way or another.
    You could even snap a corner out of the bridge to make it fit the soundhole :D
    Love that neck :p
  5. stijnkenens
    antwerpen, belgië
    I've heard that option before, and was also my first thought.
    But its the place where you rest your right hand, I don't think it would be a pleasant feeling ...
    s.
  6. Jupiter
    Osaka, Japan
    So the lacquer must've doubled the weight of that neck.
  7. Ike57
    Ike57 Tele-Meister
    Netherlands
    Well, there's no good music without suffering ánd it would reduce the weight. :lol::lol:
  8. stijnkenens
    antwerpen, belgië
    Na, don't think so, I drilled the holes for the neck mounting screws.
    The weight I lost there is back on with the lacquer ;)
    Somebody mentioned .007 strings, they will also reduce the weight :rolleyes:
    s.
  9. stijnkenens
    antwerpen, belgië
    prepared the bridge:
    Polishing my ass of right now, I've got a busy weekend, so it going to be hard to finish it, but I'm still in the running !
    s.
  10. Ike57
    Ike57 Tele-Meister
    Netherlands
    [cheering mode on] GO STIJN GO [/cheering mode off]
    Just a few hours left. See you at the finish :D
  11. stijnkenens
    antwerpen, belgië
    A few hours ...
    I would say a day, but getting there!
    No time to talk, just pics.
    Did the pup yesterday and wired the electronics:
    Ready, set, go !!!
    Grinding the pole pieces:
    give it a nice blow with a hammer:
    Does somebody know why they're coloured red on the downside?
    Hammer on frontplate:
    2 times double stick tape:
    wind !
    I've just wind the leftover of a almost empty bobbin on it ... came out at 6,40 k.
    It will do, it's going to be sharp ... very sharp ...
    Put everything together:
    total weight: 2.04 kg ...
    Wiring:
    Nut today, and some strings !
    Video tonight !
    s.
  12. Ike57
    Ike57 Tele-Meister
    Netherlands
  13. stijnkenens
    antwerpen, belgië
    yep, I know !
    s.
  14. stijnkenens
    antwerpen, belgië
    Update:
    neck didn't collapse under string tension ...
    :lol: :eek: :D :neutral: :rolleyes: :) :twisted: :rolleyes: :cool:
  15. stijnkenens
    antwerpen, belgië
    Youtube movie:
    s.
  16. williamsanders
    williamsanders TDPRI Member
    Yurup
    That's all I have to say! I didn't believe you could pull it off with that hollow neck! :!:
  17. stijnkenens
    antwerpen, belgië
    Some pictures:
    s.
  18. Jupiter
    Osaka, Japan
    I love harvest time.
  19. adirondak5
    adirondak5 Wood Hoarder Extraordinaire
    Long Island NY
    Very cool , congrats :)
  20. kwerk
    kwerk Poster Extraordinaire
    New Zealand
    Outstanding job, man. What a thing of beauty! Sounds fantastic too.
