STIFF KNOBS!!
Discussion in 'Squier Tele Forum' started by blackguts, Apr 24, 2013.
  1. blackguts
    blackguts Tele-Meister
    Saskatoon
    Ha, just bought an older CV. It is a great player but the knobs are a lot stiffer than my MIM or my MIA. Is this an age thing or a Squier thing?
  2. Bud Veazey
    Bud Veazey Tele-Holic
    Lawrenceville, GA
    The pots could be gunked up [pardon the technical jargon ;)] Get some De-Oxit and spritz 'em.
  3. IndyTeleGuy
    IndyTeleGuy TDPRI Member
    Indiana
    I have noticed that even brand new, some pots have more resistance to them than others...personally I prefer a pot with a little more resistance to it...but that's just my preference...
    If it is actually gunked up (to borrow Bud's terminolody :) ) I would think you would have a "scratchy" pot when plugged into the amp...if no scratchy, then there may not be anything wrong with it, it just has more resistance to it...
  4. SynMike
    SynMike Tele-Meister
    Vancouver BC
    I bought both brand new in the past couple of months: a Fender MIM Tele and a Squire CVC Tele. The controls on my Squier are quite a bit stiffer than on my MIM Fender.
  5. Tuxedo Poly
    Tuxedo Poly Tele-Afflicted
    Merseyside UK
    The full size Alpha pots used on higher-end Squiers are considerably harder to turn than CTS.
    If you want a light touch volume control then swap the existing pot for a vintage style CTS with the dimple underneath.
  6. blackguts
    Saskatoon
    thanks guys, mucho apreciado!
  7. andrewsadlon
    andrewsadlon Tele-Meister
    DeLand, Florida
    Yeah clean it out.
    After not playing my tele for a while, the vol pot got dirty and scratchy so I cleaned it. It's now way easier to turn.
    Which reminds me, I gotta do that to the tone pot too...
  8. Honga Man
    Honga Man Tele-Afflicted
    Colorado
    I used a pair of these the last time I put together a Tele from parts.
    http://angela.com/cts450gsolidshaft250kpotentiometersfortelessetof2.aspx
    "The brand new 450G Series is CTS's top of the line low torque 10% tolerance pot specifically designed for musicial use. Easier to use for volume swells and tone control wah wah effects than the current Genuine Fender CTS pot."
    They don't seem all that different from other pots for swells but they sure aren't stiff.
  9. surfoverb
    surfoverb Doctor of Teleocity
    Virginia
    yeah the alpha in cvc are stiffer than cts used by Fender. (by design, not a flaw)If you want similar the Mojotone CTS with the dimple, or better yet I use Bourns EVH low friction pots, these are very easy to turn, almost too much as its easy to turn them by accident.
  10. Diamond White
    Diamond White Tele-Meister
    Essex. UK
    Just dismantle them and adjust the spring tension a little, you can set them to taste. Well, it works on CTS pots anyway.
  11. crowhaven2000
    crowhaven2000 Tele-Meister
    New Mexico
    My brand new CV50's was that way. Really stiff, cleaning did nothing. I think you would have to upgrade pots to get looser controls. I tried everything, they are just that way. No pinkier swells with this one.
  12. crowhaven2000
    New Mexico
    That's the one thing I haven't tried. Prey tell, how would you go about dismantling the pot? Excuse my ignorance, I have never had one apart.
  13. stratofortress
    stratofortress Tele-Afflicted
    Maryland
    If you have the chrome knobs that have a set screw, you might loosen it up a little and pull up the knob just a little bit and find it turns easier.
  14. surfoverb
    Virginia
  15. DaveA
    DaveA TDPRI Member
    Turn the tone pot to 8 and a bit and the vol pot to 10 then add a small but well placed amount of glue between the shafts and the thread tops :)
  16. TeleTim911
    TeleTim911 Friend of Leo's
    Calera, Alabama
    Cleaner..your choice. I like to use something with lube in it, like CRC 2-26. It's up to you..everyone swears by Deoxit.
