Static on neck pickup
Discussion in 'Tele-Technical' started by riachuelo, May 6, 2021.
  1. riachuelo
    riachuelo Tele-Meister
    Mexico City
    Greetings. I have an AVRI ‘64 Tele. All stock components, and until now never a problem. It recently started making some scratchy noise, though, and I couldn’t quite place the origin. I tried cleaning the pots and the cable jack and then figured out the noise happened only when the neck pickup is engaged. BUT — the noise also only comes when I somehow touch the pickguard. I think this must be related to static buildup — I live in a very arid city — but am wondering also if it has something to do with how the neck pickup is wired. Again, it doesn’t happen with the bridge pickup.I know very little about the electronics of a guitar, but want to fix this properly — not with a dryer sheet or some other hack. I will take it to a tech soon, but thought I would seek advice here too. Thanks for any help.
  2. Killing Floor
    Killing Floor Friend of Leo's
    Austin, TX
    The bridge pickup cover should have its own ground wire. Can you check whether it’s connected to the cover and to ground somewhere?
    riachuelo likes this.
  3. riachuelo
    Mexico City
    Thanks. Will look into that.
  4. Refugee
    Refugee Tele-Meister
    Santa Rosa, CA
    Dryer sheet. I don't think there is a permanent cure. Unless you have some cool, new way of controlling electrons and protons that science doesn't know about.
    guitar_paul1 likes this.
  5. guitar_paul1
    guitar_paul1 Tele-Meister
    washington state
    I bought a can of conductive paint and carefully sprayed the back of the pickguard. Then a bit of conductive copper tape from there down to the ground. A bit more robust than dryer sheet, which will also work.
    Boreas and riachuelo like this.
  6. riachuelo
    Mexico City
    If I had a cool new way of controlling subatomic particles I wouldn’t be asking the question. What truly stumps me, and makes me wonder if it has to do with the wiring, is why this only happens with the neck pickup, not the bridge.
  7. Boreas
    Boreas Friend of Leo's Silver Supporter
    Adirondack Coast, NY
    Did you make any mods just prior to noticing the noise? Could the ground on your pickup cover be broken? I think static electricity would be a good assumption.
    I often use narrow strips of copper shielding tape in lieu of wires. You could try running a strip of copper or aluminum tape diagonally across the pickguard from the neck to the control plate (or a big X, or cover the entire pickguard), with one of the pickup mounting screws somewhere in the path. Then run either a wire from the plate/pot to where the tape abuts the plate or use a piece of doubled tape that is thick enough to contact both the pickguard tape and the control plate.
    Bongoslade likes this.
  8. jackal
    jackal Friend of Leo's Platinum Supporter
    mojave desert
    Copper tape on the bottom of the pickguard. Run a wire to ground that will make contact with said tape. I get this problem with all plastic guards.
  9. Chuck berry
    Chuck berry TDPRI Member
    Memrancook nb Canada
    The neck pickup run a ground wire from your bridge plate to your volume pot it will cure that. The pick guard there's no permanent fix when its really dry it will ping when your finger touches the pick guard. You can eliminate it for a while by passing a bounce cloth on your hole pick guard and pickups or put some moisture cream on your last three fingers. Its not a permanent fix but will last a while.
  10. Boreas
    Avoid synthetic clothing... And humidify your house - your guitars will thank you.
    Bongoslade and riachuelo like this.
  11. riachuelo
    Mexico City
    Thanks. No, no mods at all. Which is why I wonder if something that previously grounded that pickup has come loose.
    Boreas likes this.
  12. Boreas
    Check that grounding solder joint on the pickup cover. Does the pickup sound normal?
    Also, you may want to clean and WORK the switch. If it has poor contact in the neck position it could introduce more noise from that pup.
  13. riachuelo
    Mexico City
    Yeah, it sounds fine except for that occasional pop and scratch if my fingers brush the pickguard. I play fingerstyle, so I may touch the pickguard more than folks who use a pick.
    Boreas likes this.
  14. Chuck berry
    I had the same problem when l touched the neck pickup or the volume or tone button it would hum louder. I decide to put a ground from underneath the bridge plate. It cured that.
  15. riachuelo
    Mexico City
    Yeah, I guess I should update. Took it to a guitar tech I know and he shielded the underside of the pickguard and grounded it with a little wire to the plate where the pots are. Worked great. Thanks everyone for the suggestions.
