Macrogats
Thread title changed to represent more of what I’m building.![]()
How exactly do you change a thread title? I want to on one of mine, but darned if I can figure out how!
Not to dissuade you but I just looked at the website and some of the specs listed are not correct for a '59. The scale length listed is 24.75 and the actual scale was 24.562. The headstock angle is listed at 13 degrees and should be 17. The diagram shows 3 pickups instead of 2. I would be curious to know where he got his plans from.
That top is insane!
I looked at his LP59 again, & I can’t see where the 24.562 scale length. I see he has listed a 13deg headstock angle.
Do you know of a better source to purchase files like this?
Scott
I diddled around & saw somewhere, "change thread title", but can't remember, or can figure it out now.
Did some searches on the forum, & one fellow said that in the first post of the thread you have created, if the option to "edit" is still available, you do it there. I think it must only give that option for a time period, or a certain amount of posts after the original post created. I Now have no "edit" option on the first post of this thread.
Maybe this discussion, will bring attention to someone who knows the correct way to do it.
Scott
Scott - with a laminated neck like that you won't have to even consider a scarf jointed neck. Mine for Scrap Paul is Mahogany/Flamed Maple/Mahogany, and when I was trying to spray nitro the whole guitar fell headstock first onto concrete garage floor and bounced. Lessons were learned - don't hang a guitar upside down over concrete floor on a piece of ethernet cable.Well, I got back to it after a year & a half.
Glued up a laminate neck blank.
Mahagony/walnut/birdseye maple/walnut/mahagony.
Get back to it after I finish the Jazzmaster. Maybe next week.
Scott
During the Norlin years it became common (for cost cutting reasons) to use maple necks with a volute (the faithful hate them lol) that I think are not only beautiful but damn near unbreakable compared to the mahogany ones. I would simply do the volute and enjoy immunity to "Gibson syndrome" with that beautiful lamination![]()
niceWell, just getting into the preliminary stages.
Planed the clear mahogany, glued a body blank.
After looking it over real good, I noticed a check in the wood starting in from one end. Bent it over my knee to see haw far it went. At least 1/2 way into one side of the 2-piece blank. Give it a good crack over my knee.
No sense using a piece that’s cracked. Added another piece to the opposite side.
Body v2.0
My plan is to do a Birdseye maple cap, since I have some. It was up in the floor joists at my Dads for many years. He uses wood heat, so should be good & dry.
I had wiped it with naphtha to show the figuring.
Scott.
