Starting a 5F2-A build, capacitor questions
Discussion in 'Shock Brother's DIY Amps' started by JoeSixPack74, May 3, 2009.
  1. JoeSixPack74
    JoeSixPack74 TDPRI Member
    Cape Coral, Florida, USA
    I have most of the parts to build one of these in my parts boxes except some of the caps. I have a question about 2 of the caps in the Fender schematics that have values but no voltage ratings. On the Tone pot there is a .005 uF cap with no voltage listed and the cap that goes between the tone and volume pots .0005 uF. I have found the .0005 uF cap available in 500v ceramic and the .005 uF cap available as a 250v ceramic. I figure those should work but would like it if someone double checks my figuring. The only other cap I cannot find is the 16 uF 450v, from reading other posts and other sites I am substituting 22 uF 450v in there place. I probably could do that for the 8 uF caps also and save a couple bucks.
    It was also recommended going with a 12" speaker instead of a 10". Any thoughts on that?
    Figure since I am building a Tele style guitar I should build the amp too. I have the Burnt Pinecaster thread in the build forum.
  2. sjhusting
    sjhusting Tele-Afflicted
    Germany
    The cap on the tone pot isn't seeing much voltage, so just about any cap will work, ceramic, mallories, ODs, whatever you want. You might not find a .005; you can use a .0047 and there will be no difference.
    The 22uF will work fine. A 5Y3 is only rated for a 20uF, but it won't be a problem.
    Remember that the Sovtek 5Y3 (the only current production 5Y3) isn't a real 5Y3, and will give you higher voltages than you might expect.
    steven
  3. FiddlinJim
    FiddlinJim Tele-Holic
    Seee-attle
    If you want to keep it as close to the original as possible, Antique Electronic Supply (tubesandmore.com) has 16uF caps readily available. On their site, follow Capacitors -> Electrolytics -> F&T Axial Lead and you'll find them. I've been using F&Ts for everything I build with no problems. They're made in Germany and are quite a big smaller than the huge Sprague Atoms.
    They're also a great source for other things like silver mica capacitors for the low-value caps if you want an alternative to ceramic disk caps.
  4. JoeSixPack74
    Thanks for reminding me of that site. I don't know how I forgot about it as I used to fool around with tube radios.
