I will ask for some advice but first I must rant:
I'm attempting to build a 5E3 using a chassis I bought on eBay in Dec 2019. There's a minor saga of why it took me years to get around to this but I'll save it and try not to be too wordy. Turns out the chassis came from Soviet Russia, and while it looked AMAZING, I learned three things almost immediately:
1) All the holes are possibly for metric parts, or at least they were all just a smidge too small for everything. The only things that just 'bolt right up' are the PT and OT. All the jacks, switches, pots, pilot light, fuse holder, noval socket and octal socket holes are about 1-2mm too small. Or at least too small for the Mojotone Tweed Deluxe Small Parts Kit that I boughtenated.
Then I promptly discovered:
2) This chassis isn't chrome-plated mild steel. It is highly-polished stainless steel. Also, there are no board mounting holes, and I need a couple extra holes for the safety and power amp ground(s).
Then I quickly discovered:
3) Stainless steel is harder than [vulgar phrase]. My old "wood and metal" bits were probably fairly dull but they just couldn't get a bite.
So after some research I went to the Home Despot and bought some name-brand Cobalt bits that claim they can drill hard steel and cast iron. They worked better at first, but it still was probably 45 minutes and countless drops of 3-n-1 for each new hole. Including resting my wrists, it was 2 hours to drill two holes to mount the board, and of course there was drift.
Using the larger bits I was able to successfully embiggen the jacks/pots/switches/fuse holes but it was loud, difficult, and dangerous. Said bits have noticeable wear on the edges of the cutting surfaces.
I wrecked my step bit enlarging the noval sockets, and almost killed myself in the process. I have some alternative octal sockets that fit the octal holes, but I sure would have liked to use the nice Beltons for this build.
Finally, last night I went to start two more holes in the chassis (safety ground and power amp ground) and the 1/16" cobalt bits (2 in the set) wouldn't even bite. They weren't even getting warm. So it looks like I get about 2 holes with each cobalt bit until they're trash. I bought a single 1/16" cobalt bit to get the hole started, then it promptly snagged and broke. Cleaned the debris, added a fresh drop of oil, then moved up a size. Took four hours (!) to drill two holes for two #6 screws.
Plea for advice #1: Is it the wrong oil? The wrong bits? I've only got a hand-held drill but I'm going as slow as I can, and I'm putting firm but not excessive pressure down on the bits. Trying to keep them from getting hot, trying to keep them from going dull, however, I've ruined my "wood and metal" bits and just about all the useful sizes in the set of cobalt bits. I haven't found anywhere that sells carbide bits but I bet if they exist they are $$$.
Plea for advice #2: Any creative solutions to this next dilemma? Today, I discover that the strain relief hole in the chassis is too close to the weld on the side of the case:
To note, this chassis doesn't have the typical round-with-two-flat-sides type of cutout that takes the typical strain relief. Instead it's got a round 5/8" (16mm!) hole. I hunted down a gland-style cable anchor to use, but as you can see it's overlapping the side piece that's spot-welded on top of the bottom panel. I though about filing down the plastic nut on one side for clearance, but the spot weld is under it too. I'd have to remove so much material that I wouldn't trust its integrity. Would a narrow washer (to allow the nut to overlap the metal) be ok? Rubber, metal, plastic? Being that this is the primary power cord anchor I don't want to jank out. Safety!
Another option is to drill another (smaller) hole above that one and farther away from the edge, and use a 1/2" gland instead. Since I've wrecked over $80 in drilling implements on this chassis thusfar, I like that solution much less.
Plea for advice #3: What do you guys do, or where do you source "shiny and silkscreened" Tweed-type chassis? Mojotone has what appears to be a chrome-plated mild steel chassis. However, they strongly advise against drilling any holes in them as it will cause the chrome plating to start flaking off. Mojotone is a proponent of mounting grounds to PT bolts and thus don't have extra grounding holes. I'd have to drill them and then start the process of decay. There are plenty of bare-metal non-silkscreened chassis around, but in this build I'm trying for the full Fender Deluxe aesthetics.
I've been hacking on this chassis off and on for over a year, and I'm about to chuck it into the street. I'm going to cool off before doing anything rash, but I don't think buying a different one (with all the right holes) is off the table at this point.
What would a fellow Shock Brother do?
