Squire Strat Neck Swap
Discussion in 'Stratocaster Discussion Forum' started by Skip D, Nov 6, 2017.
  1. Skip D
    Skip D TDPRI Member
    Kingslang, Ga.
    I will need to replace my neck soon on my Squire Strat. SN prefix is: ICS14.. I found a new neck with tuners on e-bay.. The SN prefix is IS13... Should be a direct fit,,,, right????
  2. codamedia
    Western Canada
    Serial numbers are irrelevant... it's the model that matters.
    Most Squiers will take a standard strat neck without any issues, but IIRC there are a few models (over the years) that cannot use a standard neck as they are not scaled the same.
  3. LowThudd
    LowThudd Friend of Leo's
    Sherman Oaks, Ca
    May also have fitment issues. Necks are fit to individual guitars. When you buy a NEW neck, they are undrilled.
    It could easily fit, with some minor adjustments at most. Or in the worst case, it could need the screw holes filled and redrilled.
    The other issue is, the condition of the used neck you are buying. Is it straight? Is the nut good? Are the frets good? Etc.
    I bought a Squier standard neck on ebay, and not only were the screw holes not in the right place for my Affinity, the frets were well worn and I needed to dress them. Really, it needs a refret. Frets are really low after dressing them. But, I only paid $40 shipped, and it was worth it to have something to learn to level frets on.
    You might be better off buying a NEW neck. Fender sells Mexican necks fro $200, and I have seen them for less than that on ebay.
    Or, you could get a licensed neck from Allparts or Mighty mite. etc. They will likely be of much better quality than the used Squier neck, and possibly better than the Mexi fender neck.
    Felino likes this.
  4. Skip D
    Skip D TDPRI Member
    Kingslang, Ga.
    Thanks for the replies!!!
  5. maloburro
    maloburro Tele-Holic
    ca
    I got a new MIM Fender 50s Soft V neck and put it on a 2008 Standard Squier body and it’s perfect.
  6. metale
    metale Tele-Meister Ad Free Member
    Portugal
    For what it's worth, when I had two 90s Squier strats I once experimented with swapping necks and the holes did no allign. At all.
    Still I would like to try to put the all maple neck of my Squier Deluxe on my refinished 90s one and may give it a try one of these days.
