Hi,
I've just had my Squier Standard Tele professionally setup and can't belive what a difference it's made, it's a fantastic guitar, a real pleasure to play.
But to my question, the tone pot seems to have very little effect through it's sweep. The volume seems effective through it's whole sweep.
I'll try an explain as best I can, the pot turns through 180 degrees (12 oclock to 6 oclock), it's bright and seems unchanged for 150 degrees (12 oclock to 5 oclock) and then the last 30 degrees (5 oclock to 6 oclock) goes totally flat. The two ends are what you'd expect the tone to be like in these positions, there just seems to be little in the way of variety in between.
I don't know what value pots are used on these squier's 205k or 500k? Are they worth changing for some genuine fender ones?
And I can't see how to get the knobs of the pots, there are no allen grub screws? Are they split or solid shaft?
PS I changed the postion of the wire from the tone pot to the volume pot (well documented on this site). The tone pot control was same before this though.
Many thanks
Matt
Many thanks
Matt
