squier tele bullet
Discussion in 'Squier Tele Forum' started by Rob DiStefano, Jan 19, 2018.
  1. RoCkstAr256
    RoCkstAr256 Friend of Leo's
    Poland
    Why no surf green bullet tele....
  2. SecretSquirrel
    SecretSquirrel Friend of Leo's Silver Supporter
    PNW USA
    I haven't tried removing the nut yet, but will be doing so before long... I'll post the results!
    LutherBurger likes this.
  3. CavalierX
    CavalierX TDPRI Member
    Central Orygun
    Yes... both of mine were easy. There is a little glue and the plastic on one kind of broke up, but it was super easy to scrap out and clean up. Just make sure to use a good grippy pliers and pull straight up. The "Graph Tech TUSQ XL Fender-Style Slotted Nut - Aged White" it was a great fit into the slot (width and depth), but it was JUST a touch longer than the neck and needing sanding to round off and fit tight. The string spacing was just right though- no issues with Es being to close to the edge or any of that noise. GL
    Rockdog, DADGAD and LutherBurger like this.
  4. LutherBurger
    LutherBurger Poster Extraordinaire
    NYC
    Thank you very much. I normally tap them at one end with a punch and a hammer to get them out, but I'll remember your recommendation and try pliers when the time comes.
  5. CavalierX
    Central Orygun
    Yeah I did have to tap/dig one out after it broke up but it was still pretty clean when I was done. The first one though, pulled out so clean it could have been reinstalled. GL
  6. LutherBurger
    NYC
    Thanks again for your replies. I replaced mine with a TUSQ XL today.
    The nut in mine had been super-glued in, and I had a very difficult time removing it. Tapping it from the ends didn't work, and neither did pulling it with pliers -- the pliers only broke pieces off the top of the nut. I had to tap a tiny, chisel-like screwdriver under one end and pry it out, and then glue back in a chunk of laurel that had come out with it. Lots of swearing was involved.
    SuprHtr and SecretSquirrel like this.
  7. SecretSquirrel
    PNW USA
    Thanks for the report! I haven't got to mine yet, been putting it off as I do other stuff. But I know now to use caution. In the past, I heated nuts with a hairdryer, which seemed to help them pop out; not sure if that'll help with superglue.
  8. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Use a saw down the middle of the nut, going across the neck, and then use pliers to collapse the sides into the kerf.
    However, those nuts are ok. Just fettle the slots and graphite powder. Saves a potentially big problem.
    Players like to 'upgrade' nuts because they are inexpensive but have a huge potential for a worse setup when swapping.
    I have seen where the fancy nuts grip strings tighter because the graphite and plastic mixture compresses under wound strings especially creating a ribbed interlock.
    Dry graphite powder works wonders. Greases attract and hold dirt.
  9. SecretSquirrel
    PNW USA
    I must say, I haven't noticed any problem with the stock nut, after fettling (thanks for the new verb!) and applying graphite. But an ivory nut would just...make me feel better. :D Won't cost me anything but a little time, and I'll feel good knowing it's there.
    A more meaningful upgrade will be a new neck pickup, and since this thread is what spurred me to acquire the guitar, I think OP Rob will be hearing from me before long. :)
  10. Bruxist
    Bruxist Friend of Leo's Ad Free Member
    Kentucky, USA
    Just watched this. Sounds pretty good just stock.
  11. Rockdog
    Rockdog Tele-Afflicted
    Heart of the Commonwealth
    The stock pickups are growing on me. I examined them expecting to see the usual single ceramic bar running flush across the bottom. Instead I was delighted to see the two-bar configuration with the slugs in the middle, more or less identical to the stock MIM pickups from the 90s, some personal favorites. They just have that little extra snarl. The only downside I've noticed so far is that the bridge pickup squeals like crazy if I turn up the gain past 3 o'clock on my amp.
    SecretSquirrel likes this.
  12. Corvus
    Corvus Tele-Meister
    Birmingham UK
    God! but we are so spoiled for quality and value these days that I guess some folk have forgotten just how awful and unplayable a cheap guitar used to be. The bullets are incredible value for money and great mod platforms. Once we would have killed for something so good. Perhaps I should write a horror story on "Nasty guitars I hav eknown!"
  13. HotDan!
    HotDan! Friend of Leo's
    Belleview, Florida
    For those of you commenting on Bullet necks...They've always been held in high regard with many a Bullet giving up their necks to Partscasters.
  14. SuprHtr
    SuprHtr Tele-Afflicted Silver Supporter
    Rocket City
    For the same reason many have bought Bullets, I bought an Affinity, to use as a platform for modifications. Funny thing is, I've not changed anything out on it yet and am enjoying it! We are living in a golden age of low-cost guitar quality.
    JSKC, Rockdog, nicod98 and 1 other person like this.
  15. Danbgreen
    Danbgreen TDPRI Member Platinum Supporter
    Brooklyn
    Kept stock ‘cept for some
    Cosmetic changes. Great guitar, little heavy at just under 8bs... $129
