Squier Tele "Bullet" Pics
Discussion in 'Squier Tele Forum' started by JK202, Jul 27, 2019.
  1. JK202
    JK202 TDPRI Member
    Arlington, Virginia USA
    Hi Everyone,
    I've been meaning to post pics of my essentially stock "Bullet" Telecaster; the minor mods include the GraphTech nut and string tree and hidden behind the angle-slotted control plate - the shipping cost from Italy was more than the price of the plate! - is the nicest switch I've tried out to replace the crappy, original Cor-Tek one. This is one that's offered by DragonFire and is somewhat thicker and more robust and toggling the switch is smooth and easy. I also put on the pickguard from Musiclily - perfect fit.
    On the to-do list are replacing the tuners, bridge and possibly the pickups, although I must say I'm generally satisfied w/ how these sound!
    Cheers,
  2. Bluetelecaster
    Bluetelecaster Tele-Holic
    Waynesville NC
    Very nice,!
    JK202 likes this.
  3. jimilee
    jimilee Tele-Afflicted Silver Supporter
    Chattanooga
    Oh nice. What pickups are you gonna put in it?
    JK202 likes this.
  4. Kontaktmoi
    Kontaktmoi Tele-Holic
    San Mateo, CA
    Is this a TOP LOADER bridge? ( IE not string-through bridge). It looks like that from the picture.... in which case you have only few alternatives.
    JK202 likes this.
  5. JK202
    JK202 TDPRI Member
    Thanks jimilee and Kontaktmoi. It's string through the body actually and I'm not sure about the pups yet - so many choices out there - prolly something from either GFS or DF though. (I put a set of DF's True Texas AlNiCo5's in my Squier "Affinity" Strat and the difference from the stockers was astounding!).
  6. Kontaktmoi
    San Mateo, CA
    Consider the real Fender NOCASTER Pickups ( just make sure you don't buy the set that has the Broadcaster bridge pickup because that one is really HOT and I have seen forum entrees stating that much) . Buy them used and you won't look back!!
    JK202 likes this.
  7. FenderGyrl
    FenderGyrl Friend of Leo's
    Wisconsin
    Dragonfire Texas Tone PUPS are such a good fit for these guitars.
    $40 upgrade...makes for such an improvement. Also...replacing the electronics...
    really helps the Dragonfires shine.
    Bobby73, DADGAD, whoanelly15 and 2 others like this.
  8. Teleterr
    Teleterr Friend of Leo's
    Lewes De.
    If you like the basic sound of the p-ups, you can just replace the poles or underneath magnets w AlNiCo. Sound is close to the same , but sweeter w more sparkle in the highs.
    JK202 likes this.
  9. tom and frayed
    tom and frayed TDPRI Member
    usa
    Can anyone confirm the STOCK wire gauge that Squier uses for the 2 wires that are soldered to the output jack?
  10. TequilaCaster
    TequilaCaster Tele-Holic
    Between Time and Space, in Temperance
    Squier Bullet in Lake Placid Blue (not!) with Twang King pups, and some knob bling.
    hemmings and JK202 like this.
  11. JK202
    JK202 TDPRI Member
    Thanks for the tip - yours is as pretty as mine!
    Cheers,
    JK
  12. CavalierX
    CavalierX TDPRI Member
    Central Orygun
  13. JK202
    JK202 TDPRI Member
    Wow, that's lovely too!
    Cheers,
    JK
  14. nicod98
    nicod98 Tele-Afflicted
    Belgium
    I hope the Bullet is routed for a P90 in the neck... I have a surf green one, for which I was undecided about what to do... I should check that out! LOVELY!
  15. CavalierX
    Central Orygun
    My LPB Bullet was routed for a perfect fit. I uses some kind of dense packing foam for the back of the pick-up when mounting it into the guitar instead of the springs and it worked out great. I also shielded the pickup cavity with copper tape and when I grounded out the shielding on the PUPs wire I was sure to get a good strong connection with a jump wire off the shielding ground wire to the back of the volume pot. It is almost noiseless and sounds wonderful. I really like the FLEOR Alnico 5 Soap Bar Pickup set I got off Amazon for less than $40 for the pair. I used the Neck PUP and it matched up really well with the existing Squier ceramic bridge pup for volume/strength and tone. I still have the bridge PUP for future projects.
    nicod98 likes this.
  16. jordans0nly
    jordans0nly TDPRI Member
    Laurens, SC
    I'm really thinking about picking up the Red Sparkle one. How's the weight/quality?
  17. Vintage Fan
    Vintage Fan Tele-Meister
    Dallas
    48B6A92A-9A72-433D-8A0F-0C48B5FF5576.jpeg E92FE310-58AF-4B1A-A5A7-62DCDBB022D7.jpeg 84EAF3C2-577D-4A1F-BAE5-E25BD755E46F.jpeg I put in a vintage steel 3 barrel bridge with steel saddles on one.
    I put in a vintage steel 3 barrel bridge with brass saddles on a 2nd one. And a 6 lever palm pedal.....Seymour Duncan Hot Rails in the bridge. Fender Tex Mex neck pickup with cover removed. Wired direct to input jack, no pots, no switch. Gotoh tuners.
    Bobby73, FenderGyrl, JK202 and 3 others like this.
  18. MadJack
    MadJack Friend of Leo's Silver Supporter
    ꓶꓞ ʻɹǝๅpuɐꓛ
    I got mine last December. I was plesently surprised how good it sounded and how decently it played. It wasn't great, but pretty decent, especially for the sale price of $129.99
    The mods are Gotoh Vintage Style Tuners with bushings, TUSK XL nut, Grover Chrome Plated Brass Saddles, Fender Mint Green Pickguard and a set of Fender Tex-Mex Pickups (on sale at this time for $56.11 @ Amazon, I got mine for $47.41!). The Tex-Mex pups sound similar to the stock Squier pups, but with a slightly warmer fuller sound. They will pish you into overdrive a little quicker.
    I did do a set-up and used a foam sanding sponge to finish the fret ends and slightly roll the fretboard edge. The fret ends weren't cutting sharp, but I could feel them when running my hand up and down the neck, now it's smooth as can be. The neck finish is a thin satin poly, almost like no finish. It feels really nice and smooth, with no stickiness as with a gloss neck. The Indian Laurel fretboard is good. It does seem to soak up the lemon oil pretty quick and looks dry again fairly quickly. It still feels good, even though it looks dry.
    It still has the stock wiring under the control panel, but it's working just fine. I'll likely upgrade when something breaks down, otherwise, it will likely stay stock till that time.
    It's now one of my most played guitars and sit next to me in my livingroom.
    JK202 and FenderGyrl like this.
  19. DADGAD
    DADGAD Friend of Leo's
    Earth
    The made in Indonesia, Cort factory Squier bullet is a fine Telecaster. It has a full 42mm wide nut. Mine was a 2017 and has a rosewood fretboard. I replaced the pick guard, installed an alnico GFS pickup in the neck and a alnico pickup from my junkbox. It is humbucking in the middle position and is the first of four Teles that I grab to play. Best $129 guitar ever!
  20. JK202
    JK202 TDPRI Member
    Hey MadJack,
    She's a beauty! May I ask which specific tuners you got and from where? That's really the only gripe I have with mine. Nice job!
    Cheers,
    JK
