fretknot
After perusing FB Marketplace, I picked up an Affinity Telecaster yesterday. I've bought and modded numerous Affinity Teles in the past - several BSB, a black, and a couple red ones. This one's a Sunburst. I put an offer of $100.00 on it and it was accepted. I was expecting the usual appointments - thinner than standard body, top-loader bridge, plastic jack plate, mediocre pickups, and budget hardware and electronics. What I ended up with surprised me. I looked up the S/N on a database and discovered it was a "Special run", although it doesn't bear the FSR moniker.
It was an orphan, for sure. Never had a set-up, strings were rusty and not even worth keeping on for a quick test drive, so I got to work right away.
This thing amazed me once I got into dressing and polishing the frets and getting a good look at it.
The good:
Full 1-3/4" thickness, string-through body - it looks like a one-piece mahogany veneer, unless it's a one-piece body.
Comfortable neck with some really nice birds-eye in the grain.
Decent tuners.
Neck pickup is pretty sweet, the bridge tone is a little thin, but passable., so I was going to swap out the bridge pup for a Standard that I have on hand, but when I took off the bridge plate and saw the build quality of the pickup I was surprised to see it had a copper backing plate and the strings are grounded via that plate.
Metal output jack plate and beefier strap locks than earlier models.
The (expected) not so good:
Cheap jack (replaced with a Switchcraft jack).
Dime-sized pots that don't have a useful taper.
Switch is okay, but will be replaced with pots.
It received a proper set-up and new strings and now it is a joy to play... Squier really upped their game.
The good:
Decent tuners.
