hemingway
You might find that the saddles shift to where they want to be. That might mean that they settle centrally, or they could move to one side. In which case a bit of a sideways neck shunt might be required.
Thanks.You might find that the saddles shift to where they want to be. That might mean that they settle centrally, or they could move to one side. In which case a bit of a sideways neck shunt might be required.
Loosen the neck screws just a little, gently wrestle the neck to where you want it, and tighten up the screws.Thanks.
How exactly do you go about doing that ?
Cheers
Thanks. I’ll give it try. Although by the looks of it, the neck is already right up the side.Loosen the neck screws just a little, gently wrestle the neck to where you want it, and tighten up the screws.
I reckon it's about the most common tweak that Fenders need.
HahaLoosen the neck screws just a little, gently wrestle the neck to where you want it, and tighten up the screws.
Haha
Just did it without even loosening the neck.
Just held the lower body horn with one hand and the top of the neck with the other; then give it good pull and ...
It’s done the trick.
Thanks again.
Well, that was easy! Nice work. Looks like it worked great.Haha
Thanks again.
THIS!!! ABSOLUTELY THIS!!!Now that I really like. All Teles (and Strats) look better with maple fretboards.
@Controller -- do you know what the fingerboard radius is, on that MIM Cabronita neck?Good job. I did the same with a Bullet Tele and MIM Cabronita neck. Screwed right on.
It's 9.5 in.@Controller -- do you know what the fingerboard radius is, on that MIM Cabronita neck?
