looks good..is the high e string a little close to the edge of the fret board there or is it the angle of the pic..prolly the angleDecided to put my spare 50’s nitro neck on my bullet.
It worked out surprisingly well.
Plays and sounds great.
View attachment 943338 View attachment 943339 View attachment 943340
Will be interested to hear from moonman2 on this. It does look a bit close, even in the first pic, which seems to be full frontal.looks good..is the high e string a little close to the edge of the fret board there or is it the angle of the pic..prolly the angle
They did indeed.Did the neck holes line up?
Slightly.looks good..is the high e string a little close to the edge of the fret board there or is it the angle of the pic..prolly the angle
I think it is.What else have you done? That's not the stock pickguard....![]()
nut end vs body end ...Will be interested to hear from moonman2 on this. It does look a bit close, even in the first pic, which seems to be full frontal.
I think it is.
Admittedly I bought it used, but I assumed the plate is stock.
(Could be wrong though).
Plays great (surprisingly great).Looks like that helped. Does it play okay—that E string doesn’t slide off the fingerboard when you play it?
will do.The one I have came with a single ply. Check the pickups, they may have been upgraded.
Very nice.Good job. I did the same with a Bullet Tele and MIM Cabronita neck. Screwed right on.
