Squier Affinity Tele: would it require routing for P90?
Discussion in 'Squier Tele Forum' started by Hastings, Oct 3, 2020.
  1. Hastings
    Hastings Tele-Meister
    Simcoe, Ontario
    ....or is there enough room there?
    Thank you.
  2. FortyEight
    FortyEight Tele-Meister
    Southeastern Wisconsin
    Bridge or neck? I think we might have to see pics of your cuz I think I've seen different sized routes.
  3. Gardo
    Gardo Tele-Afflicted Silver Supporter
    Lancaster Pa
    My 2009 Squier Affinity has the neck pickup mounted to the body . It’s simple to pull the pickgaurd and see that it has a single coil route. Other models seem to have a different route .
  4. grzz51
    grzz51 TDPRI Member
    West Helena, AR
    My '19 Affinity Tele neck is routed from the factory for a HB, but the bridge is normal Tele route.
  5. Kennya123
    Kennya123 TDPRI Member
    Amesbury, Massachusetts
    I had a 2000’s affinity that had a humbucker Route in the neck slot. Not all affinities have a humbucker neck route though
  6. Hastings
    Simcoe, Ontario
    So some do, some don't. Thank you.
  7. Wildeman
    Wildeman Tele-Meister
    Norcal
    Hard to get a balance with a P90/ Tele combo, at least on mine. P90 sounds muddy. I don't want to change pots and cap because the back Tele pup sounds perfect.
    JRapp likes this.
  8. Hastings
    Simcoe, Ontario
    Thanks. I don't have to worry about that because I only use the front pickup. Does the front pickup alone sound good?
  9. Wildeman
    Norcal
    It sounds like it needs a 500k pot and different cap (muddy), the back pickup sounds perfect, it most definitely does not need a 500k pot and cap. Thats what i mean by balance. The middle position on the switch sounds good.
    I can't really find an amp setting where i like the tone from both pickups, understand?
  10. Hastings
    Simcoe, Ontario
    Yes, I understand. I have four electric guitars, and only use the neck pickup, on each of them. Thanks for the information about the pot & cap, I've made a note of that.
    ADDENDUM: I went surfing and I see the Emerson Custom sell a 3-WAY TELECASTER PREWIRED KIT. The standard Tele pickups get a 250 K pot, the P-90 and humbuckers get a 500 K, in the respective kits. I have learned something useful!
    68Telebass and Wildeman like this.
  11. 68Telebass
    68Telebass Tele-Afflicted
    Northern Arizona
    Yes- Emerson kits look like they have what you need!!
    You can probably have more fun (if you can call it that) by getting your components and soldering up yourself!
  12. Hastings
    Simcoe, Ontario
    Perhaps, but if I use the Emerson kit, odds are that when I'm finished it will still sound like a guitar.
