I'm redoing a finish on an ash body guitar because I'm heavy handed when spraying instead of light coats.
I've sanded down to bare wood and block sanding with a 5" x 3" slice of marble counter top. Finished 180 grit then will do 220 > 320. Now, should I spray shellac before grain fill or just grain fill and continue on?
I did not shellac the first time. Just grain filled several times before primer. I'm using Goodfilla water based.
Thanks
Thanks
