Spray gun suitable for small compressor?
Discussion in 'Finely Finished' started by LoudTele, Aug 15, 2010.
  1. LoudTele
    LoudTele Tele-Meister
    Wisconsin
    I have a small pancake style compressor from Harbor Freight. I have been using air brushes for guitar painting, but it's slower going, and harder to get the clearcoat to "flow" with the lower volume sprayer.
    Is there a spraygun out there that can get by with a 1 CFM at 40 PSI/.6 at 90 PSI compressor, or do I need a larger compressor?
  2. 4string
    4string Friend of Leo's
    Central California
    I am unaware of any gun besides an air brush that will run on that. Even an extremely efficient gun will realistically need more like 4 cfm @ 40 psi. You also want the biggest tank you can get for using a sprayer. I would say 8 gallons as an absolute minimum. While the pump is cycling through the on/off, the tank acts as a "bank" to keep the gun supplied with a constant pressure in the 35-45 psi range.
    You can still utilize your pancake. Set-up a "tap" line on another compressor. Plumb-in a "tee"connector with a shut-off valve into a male quick-connect, and you can quickly and easily add the pancake as additional cfm and storage to another marginal compressor. It gets kind of loud when both pumps are on, but it works!
  3. bossaholic
    bossaholic Friend of Leo's
    Maui
    If your compressor has a hard time with air brush guns, I would probably upgrade the compressor.
  4. Colt W. Knight
    Tucson, AZ
    I too would suggest an airbrush, you can buy one for about 10 bucks at harbor freight. If you like it and can figure out how to use it, I would upgrade to a nicer air brush.
