Spit and Runs
Discussion in 'Finely Finished' started by Tele Dad, May 16, 2021.
  1. Tele Dad
    Tele Dad TDPRI Member
    Northeast
    Hello experts,
    Quick question here. I am spraying LPB on a strat and have some spots from the spray can spitting a bit. I warmed up the can in water, but alas.
    My question is what to do about the spots. Keep adding coats on top? Sand them out? If so, what grit?
    I know this topic has been covered but thought I would post it fresh because I am using a metallic LPB finish and not sure if that would change the answer.
    Thanks in advance!!
  2. KelvinS1965
    KelvinS1965 Tele-Afflicted
    Wokingham England
    With metallic paints you can't really sand out defects. You'll find that the metallic will go kind of 'patchy' if you sand those spits or other marks.
    You'll have to try again on top with more coats, though you could sand back this damaged coat a bit if the spits are sticking up from the surface.
    Good luck: I just finished spraying a 'simple' light Sonic blue Strat and it took me 3 attempts (one 'overcoat' then I stripped it right back to bare wood and started again!).
    Gevalt likes this.
  3. Controller
    Controller Friend of Leo's Silver Supporter
    Montana
    I thought this might be another thread about getting old!
  4. RiversQC
    RiversQC Tele-Meister
    Quebec
    I would try waiting until dry, knock down any spit marks with really (really) light sanding if you think you can, and re-coat area. But wait for a few opinions ;)
    If you're doing this from a can, I stop and wipe the tip very often. Little build ups can form on the nozzle which will turn into spits if you dont wipe in time.
  5. Tele Dad
    Northeast
    Thanks all. Good call on wiping the nozzle.
    KelvinS1965 likes this.
  6. Rigel7
    Rigel7 Tele-Meister
    Nova Scotia
    Heya, Dad. I dunno if this will help in your situation, but once it's hard you could put a piece of painters tape on either side of the unwanted build up and scrap it away with a razor blade. I've done it with lacquer at least. I picked it up from someone who did body work on cars, so it should work for other paint types.
  7. Gevalt
    Gevalt Tele-Meister
    Vancouver, BC
    I heard this trick before. Didn't work for me, but I'm glad yours didn't delaminate. Dang 'ol rustoleum 2k junk!
  8. Gevalt
    Gevalt Tele-Meister
    Vancouver, BC
    I've refinished one guitar in metallic, about 4 times. Each w/diff. brands, as most suck. Yikes. I am no painter. HW-store cans only makes it harder, so I hope you have decent nitro. Watco is impervious to the green stripper I use on poly, so make your own decision. Most recent guitar was was done by a pro because my ol'gold one holds baggage.
    Prep is everything, esp. with metallic.
    The last 1/4 or more of the can will spit and ruin work
    wear a proper respirator, paint outdoors, and don't worship the minty gold gods partying in your blood *cough*
  9. brookdalebill
    Austin, Tx
    I thought it would be about punk rockers.
    Controller likes this.
  10. Tele Dad
    Northeast
    Thanks all. I am using Reranch nitro. I do have a respirator and am outside.
    I may try the razor blade, thanks!
  11. stratisfied
    stratisfied Tele-Holic
    Midwest
    This plus a couple caveats.
    Never press or release the nozzle when pointed at the surface you're painting. Paint in long strokes starting and ending beyond the surface you're painting.
    Make sure your trigger finger isn't overlapping the spray nozzle when depressing it. It sounds silly, but it happens and causes spitting of the paint and can even cause the paint to drip onto the surface you're painting.
    Clean your spray nozzles after use by soaking overnight in lacquer thinner.
    Lastly, spray your guitar body laid flat and supported from underneath up off the "spray table". Spray the back and sides, let it dry and then flip it over to paint the front, overlapping your spray to the sides. The paint will flow out smoother and flatter and if you don't load up the sides too heavy, you'll have no drips. Hanging the body up to spray just invites gravity to make the paint run or sag unless you're an accomplished painter.
