Specs on the P-90s in the el cheapo Epi P-90 LP Specials???
E5RSY
Georgetown, TX
Any info out there. I think they made some SGs in the same price range that had the same p'ups.
Thanks, in advance.
IronSchef
Flew here on my Dragonfly
Here is what Epiphone has to say about them.
10.01.2016
The new Epiphone P-90 PRO single coil pickup is made with 18% Nickel Silver covers and has been designed and tooled from the ground up with new bobbins manufactured to historic dimensions, Elektrisola magnet wire, sand cast Alnico V magnets, and pole shoes manufactured using correct alloys and to Gibson's original dimensions. And for you sticklers to detail, the new Epiphone P-90 PRO™ pickups also have tin plated brass base plates like used on 50's and 60's era Gibson P-90 pickups.
bgmacaw
Near Athens GA USA
It's varied between vintage wound (7k to 8k) and super hot (14k) over the years. I'd guess it's almost like what was in the parts container during a particular run unless the end customer, like Guitar Center, specified it.
Mine, purchased from GC in 1998, has the vintage wind and sounds really good. I've got a few others I've obtained used or in exchange for doing a pickup swap for someone and they've been the hot ones. While I didn't like them in their original Epiphone, some of them did really well in cigar box style guitars, like this 3 stringer.
archetype
Fiend of Leo's
Western NY
With the bolt-neck Special, I never measured the resistance of mine, but they were wax potted and Epi has stated that they're alnico magnet, but didn't specify the type.
We can assume are not P-90 Pro, as Epi wouldn't put their best pickups in a $100 guitar. I'd hesitate to assume they're the same as any other Epi P-90, as their P-90s have varied so much across different models. IMO most have been overwound and don't have the clarity they need.
IMO the one's in the bolt-neck Special sounded like good and proper P-90s.
E5RSY
Georgetown, TX
10.01.2016
Thanks, but those are a different set.
E5RSY
Georgetown, TX
On a related note: Anyone know what the fretboard wood is on these? I may be crazy, but I swear mine looks like actual rosewood (Made in 2017).
