FYI. It’s a tight fit. Make sure you know what you are getting whatever it is.
Depends on what you want to do with it in the end. If you are more of an at-home player and not trying to compete for sound, I'd stay on the low end of things regarding output - WGS Veteran 10, Jensen C10Q, even the Jensen C8R 8" is fun. Cranking a Champ wide open is most of the fun, and 5W can get loud in a hurry if you get a modern efficiency speaker. The Jensen RI speakers don't get a lot of love around here, but the C8R and C10Q are two that I love for these circuits, low efficiency being a big part, but they work great with single coils.
A Champ I built a while back through the C8R.
Here is my 5e3 through the C8R. The 8" has a distinct sound that I think is a big part of that vintage Champ tone.
And here's a 5f2a through a RI C10Q.
And someone should double check my math here, but I think that the 5k primary on your 8 ohm speaker would give an end result of 10k primary reflected back to the OT, and that should work fine.
Yet somehow Fender managed to cram an EV 10" in there for the Super Champ.
All good info. Has anybody mentioned Weber Sig 8 or 10? Two of the very most popular Champ speakers, and not expensive. The 8 is available in 4- and 8-ohm IIRC, the 10 maybe only 8-ohm. Both magnet types are popular, but alnico may be the most popular, vintage, tweed?
More broadly, 'which speaker' threads will always get wildly diverse answers, for the good reason people aim at different targets. Home or gigging? Vintage or more modern sound? Alnico (compression) or ceramic (tight)? Some speaker breakup or none? Your styles, guitars, age of eardrums?![]()
Thanks for that .I am a retired cabinet maker originaly from north California Durring the 90s I worked for Mese Boogie build thier speaker cabinets....I still build all my own cabs ,so they are all built to fit if you will. This is my first build of a small tube amp. Very simple but no instruction or data sheets or any kind of hi this a amp thank you for spending 150$ on 50 $ worth of caps and resisters and by the way ......good luck.FYI. It’s a tight fit. Make sure you know what you are getting whatever it is.
Thanks this little amp is fo Harmonica mostly so i wants it ...NASTY!!!!!!!I have a Jensen Mod 8–20 in my Champ 600. Popular upgrade.
I like it but it's not what I would call bright. If you want a lot of treble you'll need an EQ pedal. Or tweak the tone stack.
It's also not super efficient. That's fine with me as I am using this amp for quiet playing at home. But if you're looking to maximize sound level, I'd get something more efficient.
Based on Jason’s sound clips of his 5F2A and his Deluxe I just fitted a C8R in my 5F2A and I’m loving it at first impression!
Glad you like it! They really do get better with age - a solid 20-25 hours of abuse really helps. If you want a real surprise, plug an ipod/mp3 player, etc, into it - keep the source volume low b/c it gets loud quick - but play music through the amp and that speaker. You might be in for a shock at how good it sounds.
I’ll do exactly that! The lads in the Hangar can listen to their music through my amp instead of their stereo this weekend. 48 hours of Classic Rock FM on full blast should losen it up a touch! Thanks for the tip!
