Hiwatts-n-Gibsons
After the beginning of the year I am going to put together a Moon Cabinets 2×12" + 1×15" cab.
I know the 15" is gonna be on the bottom, and two 12"s on top. The 15" is a 103 db EV SRO15 rated at 8 ohms.
For the top two speakers I am thinking I need two 12" speakers right around 100 db each to match the volume of the 103 db EV in the cab. I know I need either two 16 ohm or two 4 ohm speakers to match the EV's ohm rating.
Is that correct, or can I go a little lower in efficiency if the two 12" speakers are on top? It's a straight front cab, so the top speakers will not be pointed upwards.
Also any recommendations for speakers in that range you might have paired with a 15" speaker would be cool if you have them. Make that speakers that are not EV SRO's or EVM12L's. I have SRO's, have had 12L's, and have had multiple SRO15's. The SRO 15" weighs a ton, even compared to the other big magnet cast frame 12's.
I am kinda leaning towards WGS Blackbird HP alnicos, Celestion Cream alnicos, 75hz Creambacks, or these bad boys here.
