Speaker science - Somebody teach me
EVB123
Indiana
I was at a friend's gig last night...multiple guitar players...Hendrix tribute.
Two buddies on opposite sides of the stage...both playing strats with similar pedals and amps.
Stage left: 61 strat, fender vibrolux, small pedal board. Stage volume was loud but ok. Volume and tone in the crowd was huge. Full, loud, hifi. He moved a ton of air.
Stage right: Newer strat, Dr Z (40w?), small pedal board. Stage volume was outrageous. LOUD, but full and killer tone. Crowd volume was nothing. Very thin and barely heard in the mix. I kept saying he needed to turn up, but he was dimed...and killing the guys on stage.
Speaker difference? Someone explain this speaker/amp enigma to me please.
EVB123
Indiana
Like the others have said, tons of variables. My first thought though is was the Dr. Z. open backed? I know my closed-back amps require you to be much further out in front to hear them compared to my open-backed amps.
2x12 closed back setup.
EVB123
Indiana
Both amps were nearly dimed and both about the same wattage. I'm assuming the vibrolux was a blackface openback. Still....moved way more air at a distance. And....the Dr. Z was cranked.
Had to be a difference in speakers.
I should have pushed the sound guy to mic the amps.
Wally
I would think it would have been interesting to have run each amp through the other’s speakers. I suspect the cab is the difference. An OpenBack cab disperses sound in a wider soundstage, and perhaps that dispersion pattern worked better with the room….with the sound waves bouncing off walls back into the audience????
A closed back cab is very directional. Standing that 2x12 up with the speakers in a vertical orientation might have helped because that creates a wider dispersion pattern…a wider sound stage. That might have worked better for the room. Imho, a closed back cab needs to be mic’d if one wants to cover a room uniformly.…unless the cab is a 2x cab with vertical orientation.
schmee
Yeah, too many variables. BUT, a 40 watt amp should project out well. Could be lots of things though, including even who is playing which song parts. I do think that watts dont necessarily translate into projected sound though.
Examples.
-I had a Music Man 100 watt combo tube amp years ago. RD112, or ??130 maybe? Man, that thing just would not project out. I tried a different cab finally, a 4 x 10. No change. All cabs were open back. Took it to a tech, he did a couple things, determined it was putting out 92 watts. I tried one more gig and finally sold it. Personally I think maybe it was the tone stack/architecture. It was pretty 90's mid scooped sound. Frankly, my old Deluxe Reverb sounded louder at the gig. At least on stage.
-Another story. Years ago we played at a big ex roller rink. High arched ceilings like a barn or etc. I had my 74 Vibrolux which had two Weber 10F150's in it. The band was mic'd and there was a sound man. I asked at break how it sounded. He said : "You are way too loud, even after I turned your amp mic off" My Vibrolux was on 3.5 on volume. That amp was useless/too loud with the Webers in it.
-One more: My experience with Z amps (I've had 4 in the last 20 years) is they seem to be voiced better for a bridge pickup style player. Punchy, middy and loud. Brad Paisley. But not as good for neck pickup players. This statement is a BIG generality though.
teletimetx
Frontrangia CO
Can’t rule out the room, either.
About 2 months ago, went to see a friend’s band at a new venue. Shotgun for sure; 2 large overhead speaker arrays above the stage. No wall or ceiling treatments anywhere.
My guitar player friend says both venue owner and sound guy swear the sound was perfect - in the sound booth at the back.
However, at table up front, near stage right and could barely hear a little bit of my friend’s guitar (he was stage right, playing through TM Twin Reverb); keyboard was stage left and we could only hear what his right hand was playing, none of the low end from keys; bass was center - we could hear him plenty and drums - too loud. Vocals ok.
Reports from rear right of venue were a totally different mix, and not good.
Either bad mix or bad room or both. Good luck telling that to the sound booth.
InstantCoffeeBlue
Milwaukee, WI
Did the guy with the Dr. Z have his settings overly scooped in search of the "Holy Grail Mayer Tone™️", as the Strat folks like to call it😂? Because if a big powerful amp isn't cutting on stage, overly-scooped tone settings that might've sounded good at home or at band practice (especially when combined with an already scooped guitar like a Strat) are a frequent culprit.
PARCO
VA
I once went to seea friend play. He had a 100 watt Marshall and a 4x12 cabinet. What I heard in the audience was as if he were very very far away. He had a good tone but no punch.
Cosmic Cowboy
New Mexico
99% sure it's a difference in EQ between one amp and the other.
I am guessing its an eq thing. If both amps are similar in power, it usually means one amp was not cutting through....that is a frequency (eq) thing. But yeah if you are playing that kinda gig with cranked amps....a 40 watter can run outta headroom pretty quick.
