SerpentRuss
If you're not going to have global negative feedback, the secondary of the OT does not need a ground reference, right? My speaker output jacks are not automatically grounded via the chassis connection.
Are there any other reasons to give the speaker a ground reference? If you're not using Global Negative Feedback is it better to let the OT secondary float? If you do ground the speaker side of the OT, where do you normally pick up that ground reference?
