Speaker Magnet Touching Transformer…problem?
Discussion in 'Amp Central Station' started by LKNJ, May 17, 2021.
  1. LKNJ
    LKNJ Tele-Meister
    NJ
    How big of a problem is it that a transformer may be making slight contact with the speaker magnet?
    Thanks!
  2. schmee
    Hard to say, I've had them within 1/4" of the output tranny without problems. I've mad these little plates to tilt the tranny away from the speaker before to avoid drilling a hole in a vintage chassis:
    zook and LKNJ like this.
  3. LKNJ
    LKNJ Tele-Meister
    NJ
    That is a really good idea.
  4. Mexitele Blues
    Mexitele Blues Tele-Afflicted
    Westminster, CO
    Just another day in the life of a Rivera Hundred Duo.
    LKNJ likes this.
  5. LKNJ
    LKNJ Tele-Meister
    NJ
    No issues?
  6. Mexitele Blues
    Westminster, CO
    No issues, no rattles. The speaker baffle is quite thick and solidly mounted so there is zero movement at the basket & magnet.
  7. printer2
    You really do not want them touching. Even a bit of an air gap does a lot. the magnetic flux of the speaker can go through the transformer and it may saturate early. If the transformer is touching the metal part (assuming a ceramic here) it is not as much an issue. If it is an alnico don't worry about it. If it is a speaker with a cap over the magnet structure, why are you bothering us? ;)
  8. LKNJ
    LKNJ Tele-Meister
    NJ
    it’s a 10 inch greenback, so a ceramic magnet. In order to make it fit, the plastic cover has to be removed.
  9. printer2
    Can you fit a few sheets of paper or a business card between them? Or maybe something a little more substantial than paper. I am guessing there will be a little vibration involved. A couple sheets of a pop can.
  10. LKNJ
    LKNJ Tele-Meister
    NJ
    I could put some electrical tape between the transformer and the speaker. But, not sure if that’s a good idea.
  11. Abu Twangy
    Abu Twangy Friend of Leo's
    Philly
    I've seen an amp chassis with the transformer pivoted away slightly from an overly large speaker magnet. Three new holes drilled in the chassis made the tranny stable
    LKNJ likes this.
  12. PCollen
    PCollen Friend of Leo's
    Pop, or soda ? Discuss. On second thought...NEVERMIND.
  13. printer2
    Beer would be best.
