Speaker Cable Ends/Connections
Discussion in 'Shock Brother's DIY Amps' started by stormsedge, May 28, 2020.
  1. stormsedge
    stormsedge Friend of Leo's Gold Supporter
    Tennessee, USA
    I want to put 90 degree connectors on a couple of my speaker cabinet cables. I get the difference between instrument and speaker cable...but, I do not see any specific "speaker" cable ends offered. I've ordered some 90 degree instrument cable ends figuring they will work. Any thoughts before I put one of my speaker cables under the knife?
  2. Peegoo
    Peegoo Friend of Leo's
    A 1/4" plug is a 1/4" plug. Dimensions are standard.
    Quality of materials, however, swings wildly. If you're gigging and need rugged dependability, do not cheap out. Buy Switchcraft or Neutrik brand.
    nojazzhere, studio, Blue Bill and 2 others like this.
  3. tubegeek
    tubegeek Tele-Afflicted
    Brooklyn, NY
    The "pancake" right angle connectors don't have a ton of room inside for a typical lamp-cord-sized cable. But there's no need to shield a speaker connector. So you may end up leaving the cover off, in which case, you will need to figure out strain relief for it.
    nojazzhere and stormsedge like this.
  4. haggardfan1
    haggardfan1 Friend of Leo's
    Texas, Louisiana, Texas again
    One idea for strain relief is to put heat shrinkable tubing on your cable that covers the end connectors. I've done this on the last few cables I built. It not only looks neat, but is easy to remove in the event you have to re-do that end.
    Rufus, PhredE, tubegeek and 4 others like this.
  5. Lowerleftcoast
    Lowerleftcoast Tele-Afflicted
    california
    Guitar amps are fine with 1/4 inch phono connectors.
    High wattage PA systems and Bass amps are better served with a Neutrik NL series type of connector which can handle higher current.
    W.L.Weller likes this.
  6. notmyusualuserid
    notmyusualuserid Friend of Leo's
    In the South
    Except when they're 1, 2 or 3 pole. ;)
    All of mine are Neutrik PX
  7. Peegoo
    Let's not get too pedantic...we're not bi-amping guitar speaker cabs here :rolleyes:
    PhredE, W.L.Weller and nojazzhere like this.
  8. Deeve
    Deeve Poster Extraordinaire Silver Supporter
    Ballard
    hold on there - we haven't even gotten into which direction the cables are pointed . . :rolleyes::rolleyes:
  9. Peegoo
    Okay, Ken Fischer!
    haha
    nojazzhere likes this.
  10. studio
    studio Poster Extraordinaire
    California
    Yes we have. They're pointed down!
    Deeve likes this.
  11. stormsedge
    Tennessee, USA
    LOL. Got it. Thanks for the assist. I have both Switchcraft and Neutrix located.
  12. tubegeek
    Brooklyn, NY
    Not if you're Australian!
    PhredE and studio like this.
  13. fretWalkr
    fretWalkr Tele-Meister
    DFW
    Are those left handed or right handed? ;)
    Deeve likes this.
  14. W.L.Weller
    W.L.Weller Tele-Holic
    Queens
    You can use the cheapo right angle pancake jacks, but you need a big iron to make it work before everything melts. And some electrical tape to prevent shorts.
    Also I have better luck with these when I remove the plating to make the connection between the sleeve/body and the wire. Sand/grind, wipe away grit, apply flux, then solder. Sometimes takes me 2 or 3 tries to get a good joint, since you're literally soldering a wire to a flat surface with no mechanical connection.
  15. tubegeek
    Brooklyn, NY
    If it were easy little fluffy kittens would be doing it!
    stormsedge likes this.
  16. Nickfl
    Nickfl Tele-Afflicted
    I have seen some listings for phone jacks specifically made for speaker cable that have larger terminals inside of them for the thicker conductor. I haven't tried them but I was thinking about adding a couple when I order some parts for guitar cables sometime soon.
    Andy B likes this.
  17. W.L.Weller
    Queens
    BobSmith likes this.
  18. BobSmith
    BobSmith Tele-Meister
    San Jose,CA
