Source for #8 x 2" neck screws?
Discussion in 'Tele Home Depot' started by Marn99, Apr 8, 2020.
Tags:
  1. Marn99
    Marn99 Tele-Holic
    Brookfield, WI
    So as you all may or may not know, the #8 screws on vintage fenders are 2 inches long as opposed to the modern neck screws that are 1 3/4. I have about 6 NOS nickel plated neck screws from the 50s, but I'd like to avoid buying expensive NOS screws for every build. Does anyone know where I can get nickel plated #8 x 2 inch oval head phillips screws?
    AlbertaGriff likes this.
  2. dougstrum
    dougstrum Tele-Afflicted
    blu ridge mtn cabin
    I just use SS oval heads from hardware or building supply.
    I suspect nickle plate is specialty item these days, not sure there is an inexpensive retail source:(
    SacDAve likes this.
  3. AlbertaGriff
    AlbertaGriff Tele-Afflicted
    This is an interesting one. My AV '59 Strat also has 2" screws, and the heads are a little stripped/sharp, so I have been looking to replace them. I've asked at the local Fender dealer, no dice. I e-mailed Fender and they weren't able to help either.
    Their part number (at least for the AV 59 Strat) is 0058060000.
  4. Ronkirn
    Jacksonville, FL
    are yoi sure you want 2 inches.... on most bolt-ons that will at best dislodge the fingerboard.. and it may poke through the top.. standard are 1 ¾ long...
    https://www.mcmaster.com/90315a484
    rk
  5. Marn99
    Marn99 Tele-Holic
    Brookfield, WI
    I suspect you're right unfortunately. I know there are some independent/custom screw manufacturers, but they'd probably have some sort of minimum order. Perhaps I should check with them anyway and see how bad the damage would be.
  6. RickyRicardo
    RickyRicardo Friend of Leo's
    Calgary, Alberta
    Exactly. The screws would be almost poking through. Take a ruler and measure on an assembled guitar. There is lots of info out there on how Fender did use 2" screws up until the CBS takeover but I wouldn't do it for the sake of being exactly vintage correct.
  7. Marn99
    Marn99 Tele-Holic
    Brookfield, WI
    Interesting, I wonder if they aren't willing to sell them as parts or if fender themselves has trouble sourcing them.
  8. Marn99
    Marn99 Tele-Holic
    Brookfield, WI
    Yep! ;) It is true that you have to be far more careful when drilling and installing them, but provided you stay focused while doing it, I've had no problems.
  9. AlbertaGriff
    I just looked at the spec sheet for the American Original 50's Strat, and it looks like it also uses 2" screws, but with a different part number:
    0058060049
    So maybe they are obtainable if you ask for the right part. I will try that one with my local service shop.
    As for why I use them, I want to replace the part that is already there. That's all.
  10. Ronkirn
    Jacksonville, FL
    my question would be why take the chance.. if the existing holes are stripped or just "tired". plug those rascals with a hardwood dowel and have at it with "normal" screws.. if the rationale is, longer screws = more pressure on the neck pocket which equals better anything ... that would simply be incorrect....
    r
    Steveinthesticks and Steve Holt like this.
  11. YYZman
    YYZman TDPRI Member
    Toronto
    http://www.blacksmithbolt.com/
    This place carries the 1 3/4” screws in a variety of platings (including nickel) and also offer them in slot or Phillips head.
    Kevin Wolfe, Marn99 and AlbertaGriff like this.
  12. AlbertaGriff
    Marn99 likes this.
  13. Marn99
    Marn99 Tele-Holic
    Brookfield, WI
  14. old wrench
    old wrench Tele-Afflicted
    corner of walk and don't walk
    Here's a question for ya'all -
    Back in the 1950's did Fender use wood screws or sheet metal screws?
    There is quite a bit of difference between the two different types.
  15. Marn99
    Marn99 Tele-Holic
    Brookfield, WI
    Fender used sheet metal screws, though for the earliest instruments such as blackguards, as is the case with a lot of things about them, all bets are off and it is within the realm of possibility that some may have had wood screws, a combination of sheet metal and wood screws, or all sheet metal screws. I would guess that after 52 things standardized.
  16. AlbertaGriff
    The AV guitar I am referencing uses wood screws, as are current replacements.
  17. Marn99
    Marn99 Tele-Holic
    Brookfield, WI
    Do you have pics? I've never seen wood screws on a modern fender guitar. Bear in mind that wood screws and sheet metal screws can be deceptively similar looking. I always look at the minor diameter of the thread when distinguishing the two, as sheet metal screws have a consistent minor diameter whilst wood screws taper all the way up to the end of the thread.
  18. old wrench
    Right!
    Wood screws have a consistent taper from point to head and the upper quarter or so is un-threaded.
    edit: For attaching a neck, there really is no point in having threads all the way up to the head.
    Another can o' worms :) ???
  19. AlbertaGriff
    No pics of mine at the moment, but maybe I was looking at the wrong thing.
    All I was looking at was whether there were threads up to the head of the screw. On my AV there is not.
    Like this:
  20. Marn99
    Marn99 Tele-Holic
    Brookfield, WI
    Okay so I should also clarify that there are some exceptions to the sheet metal screw thing other than blackguards. Some early Stratocaster jack plate screws were wood screws.
