Maggot
I just got a used Classic Vibe 60s Tele. It came with a regular Fender ashtray bridge and brass saddles rather than the Classic Vibe bridge and steel saddles. I have no problem with the way that the bridge sounds. However, I prefer to have a bridge plate with cutaway sides or no sides, because it makes it easier for me to palm mute. That's part of the reason that I haven't bought a Tele in a decade or so, but it can be remedied by replacing the bridge plate.
The easiest solution would be to buy a cheap vintage-style baseplate with cutaway sides from Wilkerson or Tone Ninja, attach my current saddles and go to town. Is there anything about actual bridge plates that I need to play close attention to, or will anything do? Is it possible to buy a 4-screw bridge plate for a Tele that will not do the job properly?
My other option would be to get a modern-style bridge with no sides at all and 6 block saddles, for example a Fender standard bridge with the steel saddles costs about $20. Kluson also makes a fairly inexpensive one that has 6 modern-brass saddles. The advantage would be ease of setup, and a smoother, more open feel. Disadvantage is that it's less Tele-like. Are the sonics of the modern bridge plates that different?
