Some more electronic questions
Discussion in 'Tele-Technical' started by SixStringSlinger, Jun 19, 2019.
  1. SixStringSlinger
    SixStringSlinger Friend of Leo's Silver Supporter
    Space
    I just wired my first guitar, and while not an unqualified success, it was interesting and I'm eager to try some more. I do have a couple of guitars that could benefit from a treble bleed, so:
    1) Where do you get electronic parts? Specifically caps, resistors and such. Radio Shack ain't as easy to find as it used to be.
    2) Does the value of the cap and/or resistor on a treble bleed change depending on the value of the pots in the guitar? I know two people using the same guitar may prefer different values, but is there any general rule of thumb for 250k pots vs. 500k vs. 1meg?
  2. dan40
    dan40 Tele-Afflicted Silver Supporter
    Richmond Va
    For a good selection try Antique Electronic supply (tubesandmore.com) and Tube Depot. 1/4-1/2 watt resistors will be fine but 1 watt will also work if it's easier to find. If you do a Google search for "guitar treble bleed" you will find a bunch of info on different styles and values for a treble bleed circuit.
  3. rigatele
    rigatele Tele-Afflicted
    You can order some very good cap and resistor assortment packs from China on AliExpress or Ebay. Then you have all the values on hand.
    SixStringSlinger likes this.
  4. kbold
    kbold Tele-Meister Silver Supporter
    Rule of thumb: use a resistor half the value of the pot.
    i.e. for 250K pot use 130K resistor, for 500k pot use 250K resistor
    Experiment with cap: typically 500 to 1000pF
    You forgot:
    3) Do I use parallel or series (Kinman) treble bleed??
    I use Kinman bleed (cap in series with the resistor), because it has less effect on the pots audio taper.
  5. SixStringSlinger
    Space
    Thanks, that's the sort of guideline I was looking for. And I haven't forgotten about the different sorts of treble bleed :lol: I just thought I'd experiment with that on my own. But thanks for the tip, I don't want to mess with this pot's taper.
    Have you (or anyone else) tried the treble bleed on the American Professional Series? Apparently this is how it's done:
    I'm mostly curious because it's included on the Am. Pro. Jazzmaster, and my Jazzmaster is one of the guitars I want to put a treble bleed on (it can get unbearably trebly, but I'd rather tame that with the tone knob and have the volume leave that aspect of the tone alone).
  6. SixStringSlinger
    Space
    Oh, and any idea on how to improve the taper on a tone pot that seems to have the most effect between 0 and 2? Can anything be done, or do you just have to change the pot?
  7. BorderRadio
    Phoenix, AZ
    Instead of buying a bunch of caps and resistors, I bought a V-treb for things like gold foils and Dynasonics, where I'm not sure what values work best to my ears. Down side is I still don't know what values work best, but I don't care because I just dial in the best response with the V-treb and be thankful I saved myself a few hours :)
  8. SixStringSlinger
    Space
    I was looking at those. You basically install and turn the knob till you like it?
  9. BorderRadio
    Phoenix, AZ
    Yep, pretty much. You can stick it on the back of the pot, it comes with the double sided tape already mounted. But then I can't adjust it, so I attach it with a decent lead of wire, so I can play the guitar for a few days, leaving the V-treb PCB hanging out. When I find the adjustment I like, I tuck it back in under the pickguard. Goop it with silicone if you don't want it to accidentally move on you.
  10. SixStringSlinger
    Space
    Ah, the website says it's made for 250k and 500k pots. Have you tried it on a 1meg pot?
  11. moosie
    on the roof
    The V-Treb is a nice idea, but be aware that it only varies the resistor value. The cap is fixed. To that end, it should be simple enough to measure both resistance and capacitance with a meter. I assume the cap value is not printed on the component...
  12. BorderRadio
    Phoenix, AZ
    Nah, I never use treble bleeds on 1megs because I only use 1megs on Jazzmasters. I like the high-end roll off when I pull back the volume. The only 'standard' treble bleed that I use is a 150k resistor and a 0.001uF cap both in parallel for use with Filtertrons, and only on the master volume, which is a 500k pot.
  13. radiocaster
    europe
    Back in the day I'd find all kinds of cool local places that sell electronic parts or instruments or records in the phone book.
  14. kbold
    Sounds like you have a linear pot fitted there.
    Replace with an audio taper pot.
  15. magicfingers99
    magicfingers99 Tele-Afflicted
    atlanta
    try mouser.com
    or digikey.com
    mouser has cheaper shipping and a great selection.
    also ebay for small qtys - most comes from china
    since american industry was gutted to destroy -- well you figure it out....
    Blue Bill and SixStringSlinger like this.
  16. magicfingers99
    atlanta
    amazon has some good electronic sampler kits as well, sometimes priced quite nicely.
  17. SixStringSlinger
    Space
    Hmm. It's part of a kit, so I'll check the website to see if it specifies. Any way to tell otherwise?
  18. Mark the Moose
    Mark the Moose Tele-Meister
    Erie, CO
    Well, I see you live with in space...shipping might be a problem.
    Tayda Electroncs, Mouser, mojotone, even Amazon.
  19. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Google 'guitarnutz2 treble bleed' and you'll find probably the best description of all the treble bleeds and effects of sizing the caps and resistors.
  20. kbold
    Multimeter.
    Set the pot to 50% travel and measure resistance middle lug to upper lug, then middle to lower lug. If these values are the same its a linear pot.
