Here's Merlin Blencowe's advice for circuiting stages and getting the grounding in the right place:
The highlighting is mine and I presume that what he means in the text is what's shown by the highlight I added between one stage's coupling cap and the path to the next stage's grid and cathode ground.
Now here's part of a circuit I'm working on:
In the case of V2b (the last preamp stage before the PI) I'm wondering what the function of the 470k resistor highlighted is, and whether (unlike the original amp's schematic, which shows all the grounds under V2b gathered as shown) the ground side of that resistor shouldn't be grounded instead to the same node ("C") as the PI is, since that's the "next stage" receiving the signal output from V2b.
Also (and I feel more confident about this one) at V3a, whose signal output is going through the reverb tank and to the grid of V3b, shouldn't the ground side of the Reverb switch be grounded at the cathode ground of V3b? The original schematic shows all the grounds at nodes D and below V3b ("to F") gathered together, like one big happy reverb family, but V3a and V3b are each on their own node of the power supply (D and F), so it seems to me that they should be treated as two stages that come from different filter cap sources.
And a final one, that I noticed while reviewing Blencowe's "Grounding" article:
Unfortunately, this tantalizing suggestion from the ValveWizard doesn't say how to adjust resistor values to make such a change. Should one halve the dropping resistor value in the B+ and put a resistor of equal value (half) and wattage in the ground leg that's highlighted? I'd think about a choke, but this amp has current such that it would probably be a fairly large one.
